transmission help plz
Old Oct 4, 2003 | 02:37 AM
AdiDcn's Avatar
AdiDcn
i have a code and it saids torque convertor slipage anyone knows were is that torque convertor located do i need to drop the transmission? please anyone give your oppinion
is a V6 Transmission 4R55E if im not mistaken
Old Oct 4, 2003 | 02:38 PM
oldcarbuff's Avatar
oldcarbuff
torque converter is bolted to the flywheel. It is between the engine and transmission. You will either have to pull the transmission or the motor to get to it. It is usually easier to pull the transmission.
Old Oct 4, 2003 | 03:09 PM
AdiDcn's Avatar
AdiDcn
thanx
Old Oct 4, 2003 | 03:23 PM
c_rossman's Avatar
c_rossman
Maybe just a transmission flush and filter change might do the trick, instead of replacing the torque converter. Just a thought
Old Oct 4, 2003 | 03:35 PM
oldcarbuff's Avatar
oldcarbuff
c_rossman could be correct.
I only answered the questions specifically asked. However, if the filter is clogged, it will not allow enough fluid to the converter which could cause it to slip. If it is starving for fluid, it cannot build up the correct pressure to operate the transmission.
Regards to all, JC
Old Oct 4, 2003 | 06:51 PM
micgang's Avatar
micgang
Hey. Would slippage also be caused by low fluid level? I dropped the Tranny pan on my 99 taurus today and I think that I pulled out about 7 quarts, but only had 6 to put back in. did not think anything of it, went on a test drive and felt some irregular shifting once it got warm... I was paranoind that I messed something up. Could it be the low fluid level? I checked the dipstick and it was low...
Old Oct 4, 2003 | 06:56 PM
AdiDcn's Avatar
AdiDcn
mine is overfilled but maibe is the pipe is a little bit bended were is the radiator and maibe cant give enough flow
Old Oct 4, 2003 | 07:21 PM
oldcarbuff's Avatar
oldcarbuff
could be....low fluid level could cause foaming. foaming is air bubbles mixed in with the fluid and cannot be pressurized properly and the fluid is very unstable. causes more heat buildup too because there is less fluid to transfer the heat
Gary (UT)
Mar 8, 2016 03:38 PM
Planejet42
Oct 28, 2015 02:32 PM
pboffroad
Nov 5, 2012 09:47 AM
Milwaukee1979F150
Nov 23, 2011 01:15 AM
29gp
Oct 21, 2001 11:39 PM
