1952 F1 ignition switch installation help needed
Old Dec 9, 2022 | 11:36 AM
cdc1960's Avatar
cdc1960
6th Gear
Looking for some advice on installing a new switch from Carpenters… when I bought the truck and started the restoration, the original switch was hanging down and hot wired, after several years of work I’m now rewiring the freshly painted cab, but can’t figure out how the switch is actually secured to the dash. The housing and spring line up and fit perfectly, but I can figure out if I’m missing a clip or some other part, as the switch doesn’t rotate at all, nor does the bezel. Can anyone assist? Thanks….
Old Dec 9, 2022 | 12:17 PM
51fred's Avatar
51fred
I believe it is like my 51. There is a bezzle that locks on the end sticking out the dash.
Old Dec 9, 2022 | 12:31 PM
cdc1960's Avatar
cdc1960
6th Gear
Thanks for the reply Rich, does the bezel just push on?
Old Dec 9, 2022 | 05:33 PM
26tudor's Avatar
26tudor
I believe you push the bezel on and turn it.
Old Dec 9, 2022 | 06:10 PM
51fred's Avatar
51fred
That is correct. Push on then twist clockwize if I remember correctly...
Old Dec 9, 2022 | 07:37 PM
cdc1960's Avatar
cdc1960
6th Gear
Thanks folks, I needed to gently twist the Chinese repop bezel on and off a couple of times with pliers on the bench, after wrapping the edge with tape to avoid scratching it. That opened up the required gap enough so that it could be installed while the switch was pushed into the dash from behind.
Old Dec 10, 2022 | 07:56 PM
MidwestWes's Avatar
MidwestWes
Dang those are some beautiful dashes - mine is original and not so bright and shiny!
Old Dec 10, 2022 | 08:01 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Welcome cdc1960, to FTE. We'd love to see more pictures of your truck.
I'm glad the guys here were able to point you in the right direction.
Old Dec 10, 2022 | 08:33 PM
cdc1960's Avatar
cdc1960
6th Gear
thanks for the welcome! Here’s hat it looks like at the moment…
Today’s progress
Old Dec 10, 2022 | 09:15 PM
abe's Avatar
abe
It sure is shiny and pretty, pretty and shiny!
Have you tried waxing your original dash? Or use rubbing compound.
49Bill
Jul 26, 2021 11:25 AM
j_siegel
Oct 6, 2013 02:16 PM
jat4
Aug 21, 2011 11:04 PM
Delzell
Apr 26, 2006 07:18 PM
propane32
Jul 29, 2005 05:34 PM
