Gear indicator cable repair?
Old Dec 9, 2022 | 10:48 AM
Mac J's Avatar
Mac J
My gear shift indicator on my ‘06 E350 is stuck in first gear. Shifts into all the gears fine. I examined the loop on the end of the cable and it’s broken. My Ford dealer said there are no assembly units available anywhere in the US till February.
Has anyone repaired the loop at the end
of the cable? There’s very little material to work with and looks damn near impossible to re-tie it or repair it in any way. Recommendations welcome.
Thank you.
Old Dec 9, 2022 | 12:57 PM
tabijan's Avatar
tabijan
Get what you need from a self-serve wrecking yard.
Sixto
07 E350 5.4 190K miles
Old Dec 10, 2022 | 05:15 AM
JWA's Avatar
JWA
Might find one on eBay too----typically they're part of an entire instrument cluster especially if pulled by yourself from a DIY salvage yard. That part can also be found in a similar year F-Series as those shared the cluster housing with the E-Series.
Old Dec 10, 2022 | 06:50 AM
Mac J's Avatar
Mac J
Thanks for the input. Going to a pick-n-pull today. They have an ‘05 F250. Hopefully it’s the same.
The assemblies I’ve found on EBay have been for 4-speeds.
Old Dec 10, 2022 | 09:36 AM
manicmechanic007's Avatar
manicmechanic007
You will need to pull the instrument cluster as that PRNDLE cable comes as the assembly. They can be repaired using model airplane parts. ( a smash tube ) Good luck
scty2hty3
Jul 12, 2009 04:44 PM
62stepside
23
Dec 20, 2006 03:47 AM
Hvymtlc5
Oct 7, 2005 07:00 AM
JRguy
Nov 23, 2004 02:43 AM
