GN prep and rubber bed mat.
Old Dec 8, 2022 | 08:12 PM
Squanto's Avatar
Squanto
I have the OEM GN prep and the rubber bed mat on top. I want put holes in the mat to be able to use the hitch with the in. Since I'm just using the GN with a Reese Goosebox and not a classic 5er hitch, I should only require 2 of the pucks for safety chains so I'll probably only cut 2. I'm thinking the 2 in the back nearest the tailgate would be best unless someone has some logical reason to do the other 2 or to do all 4. That rubber mat is pretty tough so I'll probably have to take it out, measure and cut. Probably use a jigsaw. Any advice for this?
Old Dec 8, 2022 | 08:22 PM
Grass Lake Ron's Avatar
Grass Lake Ron
Jigsaw is good, but you can cut it with a carpet knife. I did so last year.
Old Dec 8, 2022 | 08:23 PM
KU4OJ's Avatar
KU4OJ
Measure 8 times and cut once.
I used a harbor freight hole saw kit that went into my corded Makita 1/2 inch chuck drill motor. I don't think a jig saw would make the nice round holes you'd want. I have a Westin bed mat and that thing was a bit of a challenge to cut through.
Old Dec 8, 2022 | 08:26 PM
IADiver's Avatar
IADiver
X2 for the hole saw
Old Dec 8, 2022 | 10:28 PM
BigBlue&Goldie's Avatar
BigBlue&Goldie
I have the factory goosneck package, which uses 2 holes on each side for the safety chain mounts. I cut all 5 holes in my DeeZee mat by hand with a razor knife and it turned out great.
I would recommend laying the mat in the bed and center it up perfectly all the way around. In my case the mat was about 1/4" from the end of the bed. I then removed the mat. I used the center of the end of the bed (tailgate opening) as my datum point for measuring the hitch holes. I marked this point with a Sharpie. My first measurement was the center hitch hole from my datum point. Next, I measured out the pattern for the remaining 4 holes off the center hole. Be sure to measure these out as they weren't equal distant from the center hole.
With the mat on the ground, use your Sharpie to mark the same datum point on the mat. You can then lay out all your holes by subtracting the 1/4" (in my case) gap. I traced a roll of tape that was the perfect diameter for the 4 outer holes and I traced a cup for the center hole. I then just did a couple of passes with the RZR knife to cut them out.
Hope this helps. I got great results depsite not having a hole saw.
Old Dec 9, 2022 | 05:26 AM
senix's Avatar
senix
I used the rear two puck holes. I used a hole saw. Once I did a pilot hole and determined I was good, I inserted a piece of wood underneath the bed mat and drilled away.
When I use the 5th wheel hitch, I just roll the mat up under the tool box.
Old Dec 9, 2022 | 07:58 AM
Squanto's Avatar
Squanto
You must have a thinner mat than mine. I would have to take mine out of the truck to roll it or figure out where the holes need to go.
Old Dec 9, 2022 | 08:47 AM
ATC_F350's Avatar
ATC_F350
I have a Dualliner mat and cutting it with the hole saw wasn't the easiest, I can't imagine a box knife. I would only do the back two pucks for your use. I took measurements to make sure where to drill and like senix, I drilled pilot holes to confirm I had it right. I drilled the puck holes their actual diameter. I would make them about 1/8" bigger if I did it again, as my mat is thicker and the chain retainers actually rub against the mat, no big deal except one you have wiggle a bit to get the pin in.
Old Dec 9, 2022 | 09:56 AM
KeystoneF350's Avatar
KeystoneF350
I ended up putting a small dot of grease on the center of the puck covers that needed to be cut out, and then let the mat down on top of the grease to transfer the hole locations to the bottom of the mat. Pulled the mat out, and used hole saws for the holes.
Old Dec 9, 2022 | 10:47 AM
Squanto's Avatar
Squanto
Ahhhhhh, the old lipstick trick for making perfect holes in drywall.
Old Dec 9, 2022 | 11:38 AM
senix's Avatar
senix
mine is a heavy duty dee zee rubber bed mat
Had it for several years. I would not say rolling or folding it is easy
Old Dec 9, 2022 | 12:21 PM
Fordy20's Avatar
Fordy20
I cut mine with a tin snip. Tried other ways but it was just too thick. Tin snip worked good.
Old Dec 9, 2022 | 04:45 PM
Squanto's Avatar
Squanto
I solved the problem. When I started looking at it, i didn't like the way the mat fit so I returned it and got my points back.
DDT11
Dec 9, 2017 02:19 PM
gsxr1300
6.7L Power Stroke Diesel
Dec 26, 2013 06:19 PM
sdrono
Dec 2, 2012 10:03 AM
Tomahawk
Aug 28, 2010 07:10 PM
jvoigt
May 1, 2007 09:48 AM
