Transmission issues
Old Dec 8, 2022 | 07:45 PM
Chilltrain's Avatar
Chilltrain
4th Gear
Transmission issues
I inherited my dad's 1980 ford f350, truck has a 400m engine and a C6 transmission. That being said, I am having shifting issues with the transmission as well as a wierd ping when I put the truck into park. The transmission will shift into first and second and won't go past that. I replaced the carburetor with a Edelbrock AVS2 and am not sure if I connected the vacuum lines correctly. Any help would be appreciated!
Old Dec 9, 2022 | 05:31 AM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE
Let start with the ATF fluid level.
Up to temp in park is the level in the safe zone?
If not add or remove some to get it there.
Now under the truck under the transmission to the back you should see a vacuum line going to a valve.
First pull the hose off the valve do you see any ATF? If so the valve needs to be replaced other wise put the hose back on.
Did it fit snug to the valve & metal line? It needs to.
Follow the metal line up the back of the motor and it should go to manifold vacuum. A port that has vacuum all the time.
If that is all good it gets a little deeper and someone that knows a little more on autos will have to step up.
Dave ----
Old Dec 9, 2022 | 05:53 AM
Franklin2's Avatar
Franklin2
Start the engine and with it idling get under the truck on the passenger side and pull that vacuum line off that the previous Dave was talking about on the transmission. Does it suck on your finger when you pull the line off? If not, you don't have the vacuum lines hooked up correctly like you thought.
Old Dec 9, 2022 | 05:56 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Did it shift into third gear before the carburetor change?
Old Dec 9, 2022 | 09:06 AM
Olds64's Avatar
Olds64
^^^What they said.^^^
Hopefully you can figure it out with our help. Keep us posted.
Old Dec 9, 2022 | 07:46 PM
Chilltrain's Avatar
Chilltrain
4th Gear
Welcome to FTE
Dave ----
Ok dave so i checked the ATF fluid and i believe that its at an ok level, its hard to tell on that particular dipstick. As to the valve i pulled the hose and there was no ATF fluid on the hose and the hose was pretty tight as well. i can get the transmission to shift into reverse, first second and third but nothing past that. I do have the vacuum hose line hooked up to the front drivers side Vacuum port on my edlebrock AVS2 Carb.
Old Dec 9, 2022 | 07:48 PM
Chilltrain's Avatar
Chilltrain
4th Gear
I dont remember! LOL
Old Dec 9, 2022 | 10:16 PM
Ken Blythen's Avatar
Ken Blythen
You're going to have trouble there..........there's nothing beyond 3rd in a C6!
If you can feel 2x up-shifts (1-2 & 2-3), that's it......no 4th gear
Old Dec 10, 2022 | 06:03 AM
My4Fordtrucks
i can get the transmission to shift into reverse, first second and third but nothing past that..
So…which one is correct?
Old Dec 10, 2022 | 10:00 AM
Chilltrain's Avatar
Chilltrain
4th Gear
So after paying real close attention to the shift points i believe that the transmission gets stuck in second gear. The shifts are pretty rough from gear to gear then the transmission hangs up in second gear. I tried stomping on the pedal to see if i can get it to shift and nothing happens. I bought a vacuum gauge and tested the line going into the vacuum valve on the transmission, at idle im running 20-30. I dont know if that is enough vacuum. I dont have any fluid running out of the valve however im considering changing the valve anyway as the truck sat for a while. I did check and its not burnt, however it was a little low so i refilled which made no difference.
Old Dec 10, 2022 | 10:40 AM
Franklin2's Avatar
Franklin2
The only other thing to check, is to make sure the kickdown is not hung up and activated all the time. The gear selector lever and the kickdown lever both come out of the same place on the side of the trans. The kickdown lever will have a linkage going up to the carb. Make sure it's free and springs back to it's home position. If you are unsure, just take it loose down at the trans and make sure the lever goes back to home. I have had the kickdown get stuck in the on position and that messed the shifting up on my transmission.
Old Dec 10, 2022 | 02:37 PM
Ken Blythen
One other thing.....C6 governors, which work together with the modulator to control shifts, can get sticky & this gives shifting problems.
The easy fix is to either jack the rear of the truck onto axle stands, or find an empty road, then drive in reverse for a minute or so. This flushes the tail housing (& the governor) with trans fluid.
I've had to do this with both C6's I've owned once or twice, it's an effective fix if that's the problem.
Old Dec 10, 2022 | 02:54 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
From a standing start how many shifts do you get? One or two?
SCRWDRVR
Nov 20, 2022 11:53 AM
Bobbytr1ll
Sep 26, 2021 10:39 AM
Luis V
Feb 21, 2021 10:37 AM
Dy25634
1978 - 1996 Big Bronco
Jun 5, 2017 03:02 PM
roscoe14eb
Apr 4, 2011 09:14 PM
