1978 - 1996 Big Bronco
C6 not shifting
Old Jun 4, 2017 | 09:21 PM
Dy25634's Avatar
Dy25634
C6 not shifting
I just rebuilt my c6 got it back in the truck and running won't shift on its own but I can manually shift between 1 and 2 I go back into drive it goes back to 1st any ideas of what I may have missed or put together wrong would help don't want to tear it all apart if I don't have to
Old Jun 4, 2017 | 10:30 PM
twigsV10's Avatar
twigsV10
Did the vacuum line get hooked up to the modulator? It will rev like crazy if it's not hooked up before it will shift.
Old Jun 5, 2017 | 12:47 PM
Dy25634's Avatar
Dy25634
Ya I got it hooked up and have good vacuum tried adjusting it no difference
Old Jun 5, 2017 | 02:38 PM
Redark1's Avatar
Redark1
did you torque the valve body when you put it on. there could be some valves sticking. could be the governor too. how well did you clean everything when rebuilding this. did you flush the cooler and lines and change the converter.
Old Jun 5, 2017 | 03:02 PM
Dy25634's Avatar
Dy25634
It came completely apart and was spotless going back together and all went back together with proper torque specs according to the book I got I also don't have the kick down hooked up yet I've read several other post saying it's not needed but It doesn't sound right
Marbelink
20
Jun 7, 2025 04:36 PM
greenbeast1
May 6, 2014 11:16 AM
Huntersbo
Apr 3, 2007 12:56 PM
viper1_2001
Jan 17, 2007 07:37 PM
Fordbronco69
Nov 30, 2005 12:42 AM
