Head Studs
Old Dec 9, 2022 | 08:53 PM
brokestroke's Avatar
brokestroke
Seems like yes. HVAC box is in the way. Maybe jack front of cab or removing motor mounts is required??
Ill try to remember someone who did it in the cab and ask them.
Could be a 1 click at a time deal with the torque wrench. If I can't get a definitive answer I'll get a hold of DieselSite and pick their brain.
The fact that it's not an easily answered question attests to how few head gaskets actually fail.
Kind of reminds me of a Ford 7.8 inline 6 I have, S366 with a ported and polished head and cranked p3000 pump. A solid 380hp motor. Got to worrying about the stock head bolts (6 per cylinder) and contacted a friend of mine that pulled with a destroked 7.8 around 1200hp. He laughed and said these motors don't need to be fire ringed until 60psi and the stock head bolts will hold over 100psi of boost. Sure wish I could fit that 7.8l in a Super Duty. Cummins crusher.
Old Dec 10, 2022 | 07:02 AM
SkySkiJason's Avatar
SkySkiJason
I pulled driver’s side head in the cab once.
Never. Again.
That’s the ‘easy’ side.
I don’t think your situation requires head studs.......
Old Dec 10, 2022 | 08:21 AM
brokestroke
Never. Again.
Shot DieselSite a message about it. If it were to lift a head down the road the amount of work involved would then be 10 fold.
Old Dec 10, 2022 | 09:27 AM
Jamon Norton's Avatar
Jamon Norton
I think you are close to needing head studs boost wise but with having stock injectors I would think you are fine. I believe cylinder pressure goes up a lot with bigger injectors running hot tunes. Ik with my 200/200 injectors and kc stage 2 turbo I only see about 40-45 psi boost max, on fresh head gaskets it popped one. This is where that virgin head gasket seal is very important, that’s why you are supposed to install studs one at a time. If you are willing to spend the money to do it definitely won’t hurt
Old Dec 10, 2022 | 07:45 PM
Dmco's Avatar
Dmco
When I talked to Jake from Irate Diesel he said head studs could be done in truck, but required unbolting motor mounts or something to lean engine around.
I didn’t want to mess with that, so I skipped them and am just careful with the skinny pedal. I have 205/30 paired with a S364.5 and just keep an eye on the boost gauge.
Old Dec 10, 2022 | 07:52 PM
brokestroke
What kind of boost numbers are you seeing with that setup?
Old Dec 11, 2022 | 06:35 AM
Dmco's Avatar
Dmco
I added my original gauges before going T4, so my ISSPRO boost gauge only goes to 30 psi. I can easily exceed that if I mash on the accelerator. But normally hover between 15 ~ 25 psi while towing ~ 9,000 lbs.
Old Dec 13, 2022 | 07:58 AM
brokestroke
DieselSite got back with me about the studs. They said I should have little to no problems installing them in the truck.
Old Dec 13, 2022 | 08:28 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Installing studs in truck isn't a problem. Recommended if you are near 40 PSI.
Old Dec 13, 2022 | 08:45 AM
brokestroke
Hitting 40psi right now, stock injectors.
Old Dec 13, 2022 | 08:56 AM
Bitterroot Diesel
Former Vendor
Studs are insurance.
Old Dec 13, 2022 | 08:58 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Interesting based on what DMCO said above. Although, using "no problem" as a descriptive term can have a variety of meanings based on the skill level of the installer.
You thinking about the purchase a bit more or just going to jump in and see if the water is shallow or not?
Old Dec 13, 2022 | 09:30 AM
  #28
Bitterroot Diesel
Former Vendor
Yes, you just take the nuts off the motor mounts and trans mount and rotate the engine with a block and jack against the manifold. Replace and torque one by one.
Old Dec 13, 2022 | 09:37 AM
  #29
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
FWIW being I used to drink the Cummins coolaid.
General consensus was over 40 with stock bolts was on borrowed time also. I had a truck that would go to 45+ on stock bolts and I tried not to push it.
there are other factors to consider other than boost psi like has been stated above.
Cylinder pressure from injection event timing and obviously drive pressure.
Old Dec 13, 2022 | 11:07 AM
  #30
brokestroke
Thinking about them still. I'm pretty close to their shop in the winter.
fordf3502007
Apr 12, 2008 02:29 AM
David85
Jan 3, 2008 05:56 AM
crack
Oct 26, 2007 03:54 PM
santacruzf250
Jul 9, 2007 10:27 PM
jboard
Feb 23, 2006 06:23 PM
