1947 ford
Old Dec 10, 2022 | 01:43 PM
JBEEZY's Avatar
JBEEZY
Trailering
Originally Posted by GB SISSON
I thought you said that you didn't have a diesel in it? It's a 2 piece driveshaft, right? I think I have both sections here. You need the front or the rear? Also looks like your truck is the 131" wheelbase, not the 157". I will check what lengh mine are.
it doesn’t have a diesel in it has the flat head v8 and it is a one price drive shaft
Old Dec 10, 2022 | 05:13 PM
GB SISSON's Avatar
GB SISSON
Hmmmm , then I guess you will have to get one made. I don't think a one piece driveshaft is stock. What is the diameter of the one you twisted? It almost looks like your truck is shorter than the 131.5" SWB . Perhaps that's what is up with the driveshaft. Could you measure the axle ctr-ctr measurement? It sure is in nice shape!
Old Feb 21, 2023 | 05:03 AM
JBEEZY's Avatar
JBEEZY
Trailering
Working on it
So I have decide to get a donner truck so as of now I will have the two speed rearend to get rid of an it is massive also have a few other parts I no longer need the split rim wheels an the front straight axle
Old Feb 21, 2023 | 05:05 AM
JBEEZY's Avatar
JBEEZY
Trailering
Originally Posted by 51504BAT
Definitely not a one ton. 1 1/2 or larger. Not sure if jail bars had 2 ton versions or not. Someone here will know for sure. That said your truck looks in good shape. The stacks and bed treatment don't do it for me but its yours so my opinion doesn't matter. The cab and grille bats look amazingly straight. I can't tell from the photos about the wheels. They shouldn't be widow makers but a lot of part swapping occurs in 75 years. Worth checking, IMO. Keep posting your questions and of course more photos.
the stacks an bed have removed, an so has the rear end I got plans for it finally getting around to working on it
Old Feb 22, 2023 | 08:15 AM
GB SISSON's Avatar
GB SISSON
Just keep us in the loop and remember we love pictures!
Old Feb 23, 2023 | 11:33 PM
JBEEZY's Avatar
JBEEZY
Trailering
So the rearmed was easy to swap over to 1953 f1i need to get rid of the rear end an vacuum booster for the 2 speed rear end an I also have other parts that will possibly be coming off
Christmas
May 23, 2021 08:23 AM
gangstakr
May 17, 2021 07:28 PM
11350KINGRANCH
6.7L Power Stroke Diesel
17
Mar 27, 2011 10:04 AM
MANSON
Large Truck
13
Sep 19, 2010 01:03 PM
