D*** shift knob!
Old Dec 15, 2022 | 07:50 AM
  #46
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
The hot and cold shifter fears are no longer a concern!!! All the "cool" kids are wearing them and they will make you "hot" on the scene if you are sporting them!!!
The newest generation of driving gloves is driving mittens!!!
Old Dec 15, 2022 | 07:57 AM
  #47
FordTruckNoob's Avatar
FordTruckNoob
This one's for you @Sous .
Old Dec 15, 2022 | 08:04 AM
  #48
Sous's Avatar
Sous
FTE Emeritus
That isn't as flashy as a set of Bernie Sanders look alike mittens that keep your hands hot or cold based on your wishes. Millions suffer from rheumatoid arthritis, I bet there are fewer than 50 people with those mittens strutting around. Imagine the possibilities...
P.S. - Never mind the 1,382 reviews, that is likely the seller's bots propping up their product similar similar to how Twitter props up (deleted due to political content).
Old Dec 15, 2022 | 08:30 AM
  #49
FordTruckNoob
Musk will fix that in short order.
Old Dec 15, 2022 | 09:53 AM
  #50
2001F350dualwheel's Avatar
2001F350dualwheel
I cannot recall one time when the metal handle in my truck was hot or even too warm to use. This is to include 100° or more temperatures in the western states desert. Although, I have tinted windows and a nearly clear 99% UV blocking film on the windshield. Also, my metal T-handle is polished and lightly brushed aluminum, so it reflects any direct sun exposure it receives through the open windows.
I could see if the handle was dark colored where it would retain heat and be too hot to "handle" in a truck that does not have UV protection. That would likely be the case for any material including wood, metal or plastic though, similar to the dashboard in the AZ July sun.
I dont know what to tell you man. I know mine got hot in the sun. A lot of times it was direct sun. Maybe that was the difference. I had both the steel ball and I put one of those gun revolver cylinder type. The plastic factory one was the best feeling for
me so I ordered one and I strictly use factory shifter. The original one was so loose that the splines tip actually poked through the top. A new one was $25 bucks.
Old Dec 15, 2022 | 10:19 AM
  #51
Sous's Avatar
Sous
FTE Emeritus
It's all good sir. My inability to recall one time that the metal T-handle was hot or warm beyond ambient air temperature could be due to several factors including my failing memory. I am willing to bet dollars to donuts this summer I will pay much more attention as I get into the truck and especially in places out west in the high desert.
Granted, I don't have a typical truck regarding the windows with the UV blocking tint. I put a similar tint on the east facing windows in my home and they have kept the floor and other things from being sun bleached for many, many years now. We don't get west sun due to the tree line on the south and west sides of the property. I installed the tint on the house in order to help with the AC bill as well as preserve the hardwood floor. I figured it might be a good idea to do the windshield of the truck as well as the 20 year old AC struggles a bit at times when in 100° or higher weather. This has been a great addition to the list of accessories in the truck.
As I mentioned, we liked the result so much that we installed it on two of our other vehicles. This past summer as we were racing across UT, NM, WY, etc it was really nice to have the UV blocking tint on the windshield.
My original shift handle was in as poor shape as what you describe and I saw this T-handle when searching for a replacement. I decided to give it a shot as it was only a few bucks and here we are almost 10 years later.
Old Dec 15, 2022 | 11:07 AM
  #52
2001F350dualwheel
I can’t remember if it was tinted at the time. But I had times even with tint I grabbed the shifter and shifted with two fingers. I ended up wussing out and had a small hand towel over it on really hot days. My truck sat in the sun 24/7. The rubber shifter …I don’t even notice heat or cold.
Old Dec 17, 2022 | 09:44 AM
  #53
254partsguy's Avatar
254partsguy
When I was running my 01 f650 rollback I had one of the revolver cylinders on it. Ragged old truck with crappy ac at best in the Central Texas heat on I35 in the summertime with the windows down. My boss got in it to reposition it for me on a recovery once and screamed it was hot as hell, I giggled cause I've been on fire so many times welding it takes a lot of heat in the hands for me to feel uncomfortable.
Old Dec 17, 2022 | 01:29 PM
  #54
2001F350dualwheel
I was out in AZ one time and ingktninnthebteuck…I swear there was a burned imprint of the 6 shooter bullets and cylinder on my palm for a week. I remember shifting with two fingers….really fast.
Old Dec 27, 2022 | 06:25 AM
  #55
Sous's Avatar
Sous
FTE Emeritus
@2001F350dualwheel , I will admit when I am wrong in an attempt to learn from my mistake and to hopefully not repeat the mistake. This time though the ignorance may have been bliss...
This week north GA had a cold spell, like a lot of our great nation. It was 9° one morning when I ran out to the the garage, which is not insulated or climate controlled and is detached from the house.
I needed to get two wrenches in order to remove and replace fittings on an air compressor hose in the basement. Turns out the wrenches were cold to the touch, as expected. The first thing that came to my mind was this conversation and "well duh..."
I can only assume I had not noticed the cold or hot sensation from the metal T-handle gear shift because I was preoccupied with what is going on with the truck or environment. 99.9% of the time I don't wear gloves when driving, so the insulating properties of that possibility were not present. I bet each time I go to start the truck in the future and forever, I will recall upon this thread and conversation and smile just a bit based on the hot, cold or comfortable feeling of the shift handle.
Perhaps if the handle varies in temperature too much as you indicated and eluded to, I may make my own handle out of a nuce piece of hardwood like walnut, cherry, honey locust or cedar as woodworking/wood turning is a passion and hobby I am learning about every day.
Old Dec 27, 2022 | 09:20 AM
  #56
2001F350dualwheel
lol. Yeah unfortunately we don’t get that cold out where I live. Coldest we get is maybe high 30s low 40s but we do get 110-115* heat.
i can definitely see metal getting cold enough where it’s like holding a block of ice for a little while. The nice thing is that once the cab warms up and everything heats up the shifter **** will
be more bearable to hold on to.
I’ve been watching the news …man I hope everyone on the east coast impacted by that storm is ok. I’ve been reading that people have already died in Buffalo. So sad to hear that.
BTW wood shift *****.. that would be cool.
I asked my BIL to help me make a drink holder surround when my rubber/foam center seat drink holder did it’s peel away from the plastic backing. Still looks good 8 years later
Old Dec 27, 2022 | 10:18 AM
  #57
Hyakkimaru's Avatar
Hyakkimaru
Why don't you make you a wooden cup holder to go behind the shifter? I made mine with a chainsaw and it's very crude but it's another spot to put cups LOL! Or coins and.... Junk.....
I know that first picture sucks, my bad. I just made a wedge out of a firewood round and it wedges right up under the seat. That should have made the wedge a little thicker though. It was a little crooked as well. I did it with the chainsaw. I even made the cup holes with the chainsaw. Very crude, but I don't really have any woodworking tools so it got the job done anyway LOL gives it character
Old Dec 27, 2022 | 05:19 PM
  #58
FordTruckNoob
How about a custom resin **** with something pretty embedded in it?
Old Dec 28, 2022 | 02:20 PM
  #59
Sous's Avatar
Sous
FTE Emeritus
https://youtu.be/Wk985JXyBuY
Turns out I have ~2 gallons of resin on hand, literally tons of amazing wood of a variety of species and a good friend that just took on laser engraving and carving.
Maybe I could make something and ask him to put the shift pattern on it.
So many fun projects and so little time... 2022 went by incredibly fast for our family...
Old Dec 28, 2022 | 04:53 PM
  #60
FordTruckNoob
If you want to get really fancy, embed a shift pattern insert in the resin and turn the material until the shift pattern is exposed.
