HPOP Check Valves
Old Dec 4, 2022 | 12:41 AM
Fordworth's Avatar
Fordworth
HPOP Check Valves
I recently replaced the high pressure oil lines and fittings on my '02 a typical aftermarket kit that uses JIC fittings. This requires removing the check valves from the pump since the fittings aren't machined for the springs. I read several posts on different sites where people said they had no bad effects from pulling the check valves but now it takes a solid 10 seconds of cranking to fire the engine, even immediately after shutting it off. Does anyone here have any experience with removing the check valves or any thoughts on any other causes of the hard starting?
Old Dec 4, 2022 | 12:54 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I do not think removing the check valves from the HPOP will cause that hard start. Pretty sure. Prolly. I guess.
Before trying to start pull the allen head plug from atop the HPOP reservoir. The oil level should be about 3/4 inch from the top. If lower than that the engine needs to crank to fill that volume before oil is available to fire the injectors.
Old Dec 4, 2022 | 07:56 AM
jstihl's Avatar
jstihl
How long have you run the truck since changing the hpop lines? You might still have some are in the lines as it takes a while to purge the air out. Removing the check valves will not cause hard starting, You might find that it takes one or two seconds longer to start but not what you are describing
Old Dec 4, 2022 | 08:16 AM
udsuth78's Avatar
udsuth78
Agree with all of the above and recommend hooking up a scan device to monitor ICP and IPR DC% while starting. If you don't already have a scan tool then would suggest checking out the tech section in the stickies and read through the info about Forscan. It is the best and most affordable option we have for these trucks hands down.
Old Dec 4, 2022 | 08:19 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I replaced my HPOP lines and removed the check valves (disc and spring) in the HPOP side fittings when I replaced those as well. I noticed no delayed starting, longer starting and certainly not 10 seconds of starting. Especially if I restart the truck immediately after turning it off. I too was concerned about the "delayed" starting, but that turned out to be an internet myth, at least in my case.
You did right by coming here and asking the question flat out as the other posts on "different sites" were steering you wrong. If you are referring to Facebook groups, you have to be very careful with any information you glean from there. It is riddled with false and fraudulent claims.
Don't take my word for it though, hear for yourself in the video below. This is my truck starting after sitting for 2 weeks and then after sitting for a few minutes after I ran into the store.
Old Dec 4, 2022 | 08:23 AM
Sous's Avatar
Sous
FTE Emeritus
In addition and to piggyback on what the other fellas have written above...
FORScanCheck out the link above for an ideal scan tool setup that Udsuth78 was referring to and the 7.3L PSD Tech Folder is a wealth of information.
Old Dec 4, 2022 | 05:44 PM
Wes444's Avatar
Wes444
Hype. Maybe a half second delay after removal, could be the rest of the work done at that time tho. Went from split shots to single shots. Nothing to be overly concerned about
Old Dec 5, 2022 | 12:49 AM
F350towing's Avatar
F350towing
Over 2 years now on the jic with check valve’s removed.
Nothing as a noticeable difference in cranking time to it flashing up.
T6 oil did make a difference, longer cranking time during summer heat. Enough for me to notice, not enough to be concerned. Definitely flashes quicker during winter months.
Anything else you did while replacing the HPOP lines that could be a contributing factor?
Old Dec 5, 2022 | 02:42 AM
Fordworth's Avatar
Fordworth
Thanks for all the responses. I'm sorry I didn't get a chance to look at them earlier but I've been working goofy hours lately. My info certainly did not come from Facebook since I've never been on it. Just a couple of diesel specific sites that said the same thing as y'all- pulling the check valves doesn't cause hard starting. I haven't driven it more than a few miles yet because I have a list of projects to do on it so I'll give it some more time and read up on your suggestions. I appreciate all the help.
Old Dec 5, 2022 | 02:56 AM
Fordworth's Avatar
Fordworth
Old Dec 5, 2022 | 06:00 AM
Tpayne621's Avatar
Tpayne621
If it hasn't been drove much that's the problem. It can take a while to get all the air out. Need to drive it like you stole it for a good while. Atleast 50 miles. Some say 100.
Old Dec 5, 2022 | 05:16 PM
Fordworth's Avatar
Fordworth
I definitely will but it will be a minute before I can. Just pulled the bed off this morning before work to get to another project on it. Thanks again.
23larry24
Nov 5, 2013 09:09 PM
OldBlackCat
Feb 26, 2013 09:35 PM
BadDogKuzz
15
Feb 27, 2012 11:23 PM
88f1504x4
May 2, 2011 08:18 PM
B Girard
Mar 24, 2011 02:57 PM
