Hard starting issue
Old Dec 2, 2022 | 09:56 AM
automaticlee's Avatar
automaticlee
Hard starting issue
My 96 powerstroke normally fires on the first key cycle. Lately i go thru about 4 or 5 cycles before starting since colder weather.. It makes a lot of white smoke while cranking. I just replaced the CPS with an autozone part. I dont suspect that cause it does start eventually. I eliminated the fuel heater in the filter housing last year after winter. Could that be an issue in colder weather? Also getting engine temp light when cranking. Any advise is appreciated.
Old Dec 2, 2022 | 11:06 AM
knottyrope's Avatar
knottyrope
is your GPR working?
volts should drop to about 10.5 when first turned on when GPs are working.
Mine would pull in but connector was corroded.
can put a wrench on both big teminals for 20 seconds and see if it starts up after, if it does then maybe GPR is bad or corroded term.
can pull off the UVCHs on valcovers and ohm out the outer pins to group to check the GPs. should be about 1 ohm.
Old Dec 2, 2022 | 04:45 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Sounds like your glow plugs aren't up to the task. Only buy Motorcraft sensors for your truck
Old Dec 2, 2022 | 05:01 PM
Hit Man X's Avatar
Hit Man X
Plug in for three or four hours. Report back regarding cranking ability.
My guess weak batts, janky cables, and a lame starter.
Old Dec 2, 2022 | 06:44 PM
Harveyearlolstad's Avatar
Harveyearlolstad
Try cycling your glow plugs for two minutes each, twice. To get those glow plugs really glowing I would not rely on the "Wait to start" light. Have u tested the resistance on your glow plugs?
Old Dec 3, 2022 | 05:59 PM
tjc transport's Avatar
tjc transport
i ain't rite
cycling glow plugs does no good if they are not working.
as said, plug the block heater in for two-three hours before cold start. if it fires rite up, your glow plug system need help.
i would start with the relay. they are a known weak spot.
Old Dec 6, 2022 | 11:41 AM
Harveyearlolstad
Isn't possible that now temps are dropping the glow plugs may need more time to heat up? In the summer compared to the winter I noticed a difference. We have a swing of 60 degrees difference between season here in california. Also, if giving the glow plugs more time to heat helps the starting issue then you are pinpointing your issue to the glow plugs. ?
Old Dec 6, 2022 | 12:20 PM
automaticlee
I plugged it in for an hour and it started on the first cycle (45 seconds). I'm going to replace the plugs. I'm happy to know what the problem is. Thanks for the help.
Old Dec 6, 2022 | 12:34 PM
z31freakify's Avatar
z31freakify
If you do glow plugs only buy OEM from a trusted source like a dealer, riffraff diesel etc, there's lots of counterfeits in the web that look genuine like in Amazon or eBay.
Check armature Clarence on the injectors, they could also contribute for the hard cold start. I would send them to get rebuild if money is of no concern and perfect time to upgrade them to something peppier or shim them if you are in a budget.
Old Dec 6, 2022 | 01:29 PM
tjc transport
i ain't rite
before buying glow plugs, check the relay. they go bad a whole lot more often than the glow plugs do.
why spend $90 on glow plugs only to find out the relay was bad and than have to buy that too.
Old Dec 6, 2022 | 03:40 PM
knottyrope's Avatar
knottyrope
no need to use GP for 2 minutes unless you have some bad issues and it wont start
i wait 5 sec after WTS and it always starts in winter.
when above 50, i crank and go and it starts
below 25, needs block heater for me
Old Dec 6, 2022 | 04:22 PM
tjc transport
i ain't rite
yup. when WTS goes out, turn the key and off i go.
Old Dec 29, 2022 | 06:07 PM
automaticlee
I got the right valve cover off. The inner rear harness plug is a little cooked at one end. And one plug was disconnected. I checked resistance on the plugs. All read near 0.52 to 0.65. This is with neg probe on the negative battery terminal, pos probe on the end of the plug. Is that correct? I'm thinking change both inner harness and save the gaskets. Any thing wrong with reusing the gaskets?
Old Dec 30, 2022 | 03:49 AM
tjc transport
i ain't rite
sounds like you found your issue.
if the gasket is not ripped or melted, you should be good replacing just the harness.
sunuvabug
13
Nov 4, 2019 01:24 PM
Mason33
Feb 4, 2019 08:43 PM
alwolfer
Dec 22, 2018 10:02 PM
e.alleg
15
Mar 13, 2009 09:35 AM
gatorpsd
Jul 2, 2007 04:08 PM
