Manual choke placement?
Old Nov 30, 2022 | 08:05 PM
Kmg123's Avatar
Kmg123
Any ideas on where to put a manual choke? Don’t really want to drill through my dash. It’s an 89’ f250 XL
Old Nov 30, 2022 | 10:16 PM
My4Fordtrucks's Avatar
My4Fordtrucks
How do you put a manual choke on a fuel injected engine?
Old Nov 30, 2022 | 11:48 PM
Kmg123's Avatar
Kmg123
its engine swapped with a 5.0. It’s carbureted, it’s not stock
Old Dec 1, 2022 | 06:06 AM
My4Fordtrucks
Oh….
Drill or use an existing hole in the firewall. Mount it under the dashboard.
Old Dec 2, 2022 | 01:59 AM
AuroraGirl's Avatar
AuroraGirl
Show us the engine bay. on a manual choke you want to avoid the harsh curves with the cable. In my opinion, you would be wiser to use an automatic choke, but your vehicle. An automatic 2 wire choke for an edelbrock, for example, can be wired pretty easy with a fuse tap and some wire to the positive and a short run to the base bolt holding the carb to the engine for a ground.
Old Dec 2, 2022 | 07:04 AM
My4Fordtrucks
My early Bronco has a manual choke and the Jeep has a thermal choke. Both of them work fine. I also don’t see the need for a manual choke in this case since and electric choke is all that’s needed and easier to install.
Old Dec 2, 2022 | 09:14 AM
AuroraGirl's Avatar
AuroraGirl
id personally hate sitting outside in the coldest part of the year for enough time to open the choke and then go inside till its warm lol! Did that enough when I was young for my dad(The qjet never quite liked starting cold)
scottlane
Mar 23, 2022 06:25 AM
Jon Hess
Jan 21, 2011 08:54 AM
sammycooks
Apr 4, 2010 03:41 PM
dj53
26
May 5, 2005 06:31 PM
Sedric
Oct 7, 2002 08:35 PM
