random bad contribution test
Old Dec 20, 2022 | 11:59 AM
dmueller71's Avatar
dmueller71
Also when running tests, theb perdel on 8 bounces between 5.2.5 and 6.86
Old Dec 20, 2022 | 01:01 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
It would be like winning the lottery if you got an in spec set of injectors from that company.
Old Dec 20, 2022 | 08:02 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
You could try swapping injectors 2 and 4, see if the problem follows the injector.
If it does it points to a bad injector. If #2 is still bad then the wiring is suspect.
Old Dec 21, 2022 | 12:39 PM
dmueller71's Avatar
dmueller71
yeah. Been regretting the decision​​​​​​​
Old Dec 21, 2022 | 12:40 PM
dmueller71's Avatar
dmueller71
Originally Posted by aawlberninf350
You could try swapping injectors 2 and 4, see if the problem follows the injector. If it does it points to a bad injector. If #2 is still bad then the wiring is suspect.
that's how i got to this point. Issue was on #4. Switched 2 and 4 and problems moved to 2. Got a new injector and problem persists.
Old Dec 21, 2022 | 08:01 PM
jstihl's Avatar
jstihl
Originally Posted by dmueller71
Installed 180cc stage 1 from Full force deisel. With tunes from AA I also did injector cups on the drivers side. Wondering if I still have #2 leaking
FFD is most likely your problem. I swear it seems like every other week someone is posting about a problem with their FFD injectors that they just installed. I've had their injectors, lesson learned... You will need to go through all the diagnostics but it is not uncommon for them to send out a replacement injector that is bad also
Matt Pace
6.7L Power Stroke Diesel
Jul 10, 2021 01:38 PM
Jsamsonite
May 16, 2015 10:30 AM
LSAtexan4x4
Mar 14, 2013 02:32 PM
AndysFords
Aug 30, 2009 05:59 AM
caseydudem
Jan 1, 2008 11:40 AM
