Help
Old Nov 22, 2022 | 02:05 PM
DALFAM's Avatar
DALFAM
6th Gear
Help
My 2007 ford 6.0l I changed oil cooler now wont start
its got over 1000psi at cpc sensor.its like slow timing it tries to start engine cranking speeds up when cranking but just wont finish starting
Any ideas
Old Nov 22, 2022 | 02:30 PM
IHateCommieCars's Avatar
IHateCommieCars
It often takes a lot of cranking to get the air out of the system. If you haven't recharged the batteries at least once, you're maybe not there yet.
Old Nov 22, 2022 | 03:33 PM
bismic's Avatar
bismic
In addition to the advice above, monitor the ICP volts so you know the actual ICP pressure and not an "inferred" one.
Old Nov 22, 2022 | 04:32 PM
Hartwig's Avatar
Hartwig
You had published somewhere a table with the comparison of ICP volt and ICP psi?
Old Nov 22, 2022 | 04:41 PM
bismic's Avatar
bismic
The attachment is from Ford. IIRC it is for the 05 and up engines, but it should be close enough for any engine IMO.
voltage vs pressure
