1960 Ford F100 4x4 - what is it worth?
Old 11-21-2022, 09:42 AM
Dpginc's Avatar
Dpginc
Dpginc is offline
8th Gear
I have this 1960 F100 4x4 and interested in selling it. What do you guys think it is worth? Clean Title. No motor, trans or transfer case. Located in Colorado Springs, Co 80831
The following users liked this post:
Old 11-21-2022, 10:53 AM
Ibex's Avatar
Ibex
Ibex is offline
I think like anything it is worth whatever you can get. As for the 4WD I really don't see what it would add to the value. The only thing 4WD on it is the front axle and maybe the springs. And a lot on the value depends on the location. Also, more pictures of all sides and interior would help a lot. Good luck on your sale and I hope you get what you want.
Old 11-21-2022, 12:36 PM
Byrd.Dog's Avatar
Byrd.Dog
Byrd.Dog is offline
Looks like it was converted to a 4x4. As far as I know, ford didn't make a short box 4x4 in 60.
Old 11-21-2022, 06:10 PM
spurredon's Avatar
spurredon
spurredon is offline
Isn't there some extra bracing under the 4x4's? Seems like that was discussed quite awhile ago. Would be a clue if it were indeed factory, but what about the VIN? Doesn't that indicate 4 or 2?
Old 11-25-2022, 02:40 PM
tripleframe's Avatar
tripleframe
tripleframe is offline
Originally Posted by spurredon
Isn't there some extra bracing under the 4x4's? Seems like that was discussed quite a while ago. Would be a clue if it were indeed factory, but what about the VIN? Doesn't that indicate 4 or 2?
Good points to determine value. Many possibilities to what happened here. A shortened long wheelbase 4x4 frame? A 2WD converted to 4WD? Original paint patina may be a big plus to some. Several more photos are in order to come close to a ball park figure.
Old 11-25-2022, 04:36 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,660 Likes on 1,355 Posts
Is this truck currently registered with a license plate and tag and all? In your name? Is this the same truck:
https://www.ford-trucks.com/forums/1...1959-f100.html
Old 11-29-2022, 10:08 PM
63flareside's Avatar
63flareside
63flareside is offline
does the vin on the title match the vin number on the frame?
Old 11-29-2022, 10:38 PM
Dpginc's Avatar
Dpginc
Dpginc is offline
8th Gear
Not same truck, I have both a 1959 and this 1960
Old 11-29-2022, 10:39 PM
Dpginc's Avatar
Dpginc
Dpginc is offline
8th Gear
Yes, this 4x4 1960 has title
Old 11-30-2022, 12:58 PM
63flareside
picture of the frame vin?
Curated Content Editor
17
10-13-2018 08:24 AM
1KILLERZ
08-25-2017 10:38 AM
custercountyboy
07-31-2009 06:56 PM
White_Knuckles
03-20-2008 03:30 AM
cbarny
08-02-2007 02:11 PM
Quick Reply: 1960 Ford F100 4x4 - what is it worth?
