1960 Ford F100 4x4 - what is it worth?
I have this 1960 F100 4x4 and interested in selling it. What do you guys think it is worth? Clean Title. No motor, trans or transfer case. Located in Colorado Springs, Co 80831
https://cimg2.ibsrv.net/gimg/www.for...32027c18e3.jpg |
I think like anything it is worth whatever you can get. As for the 4WD I really don't see what it would add to the value. The only thing 4WD on it is the front axle and maybe the springs. And a lot on the value depends on the location. Also, more pictures of all sides and interior would help a lot. Good luck on your sale and I hope you get what you want.
Looks like it was converted to a 4x4. As far as I know, ford didn't make a short box 4x4 in 60.
Isn't there some extra bracing under the 4x4's? Seems like that was discussed quite awhile ago. Would be a clue if it were indeed factory, but what about the VIN? Doesn't that indicate 4 or 2?
Originally Posted by spurredon
(Post 20637994)
Isn't there some extra bracing under the 4x4's? Seems like that was discussed quite a while ago. Would be a clue if it were indeed factory, but what about the VIN? Doesn't that indicate 4 or 2?
Is this truck currently registered with a license plate and tag and all? In your name? Is this the same truck:
https://www.ford-trucks.com/forums/1...1959-f100.html |
Originally Posted by 85e150
(Post 20642456)
Not same truck, I have both a 1959 and this 1960
Yes, this 4x4 1960 has title
Originally Posted by Dpginc
(Post 20647329)
