Inner driver door cable issue
Old Nov 20, 2022 | 02:38 PM
TravisBeam22's Avatar
TravisBeam22
4th Gear
On my 1989 f150 single cab, the door won't open from the inside because the cable is broken. I have half a mind to leave it as is and just continue to roll down the window to open the door. I also would like to open my door from the inside... It doesn't look too difficult, but difficult enough to replace. What are your thoughts?
Old Nov 20, 2022 | 06:43 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I bet if you remove the door panel you will see that there is a rod and not a cable for the inner door handle. Look to see why it isn’t releasing the latch.
Old Nov 23, 2022 | 05:03 PM
kevinv10's Avatar
kevinv10
@My4Fordtrucks is correct. It is a simple rod linkage, and I am thinking the grommet holding the rod in place broke, and the rod fell off. If you feel no resistance when you use the interior handle that will be a sign of this. Pull your door panel off and it should be really obvious.
dcara
39
Jul 19, 2019 04:38 AM
GavinL
Nov 21, 2018 12:51 PM
Wilmax
Sep 28, 2017 11:00 PM
breisr
Oct 7, 2009 08:40 AM
NewMexEbayF250
Dec 26, 2004 11:02 AM
