Locked Rear Cargo Door
Old Sep 28, 2017 | 08:13 PM
Wilmax's Avatar
Wilmax
A couple days ago I loaded my Ex and took off when I went to unload it the drivers side rear door(cargo door) would not open. Has anyone had this happen to them, if so what must be done to get it open?? Thanks, Max
Old Sep 28, 2017 | 08:15 PM
metru's Avatar
metru
chances are you will need to unscrew the handle and try to find the rod in the door or the door catch and manual open it with a screw driver or some stiff rod
Old Sep 28, 2017 | 10:22 PM
ArmyLifer's Avatar
ArmyLifer
I fixed mine according to this write up in the tech folder: https://www.ford-trucks.com/forums/1...l#post15894412
Old Sep 28, 2017 | 11:00 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
AL^^ has you on the right track. Basically, what happened is the plastic cable anchors broke on the end, and now the cable is flopping around in the door instead of working the latch. You might need to remove the interior panel to get the door open if you can't fish the end of the cable out next to the side-mounted latch. To fix it, you will certainly have to remove the interior door panel.
4x4Junky
Apr 7, 2016 12:25 PM
Polkster
Nov 16, 2013 08:49 PM
krzldy1949
1997 - 2003 F150
Mar 9, 2013 12:39 PM
1st250
Apr 30, 2010 07:55 AM
