Towing
Old Nov 20, 2022 | 12:46 PM
Mrwoodbead1969's Avatar
Mrwoodbead1969
5th Gear
Towing
Hi all I’m looking to tow my 47 Ford pickup on a trailer behind my wife’s 52 f100 to some beach races does any know if the 52 would be capable of towing it both vehicles are standard. Many thanks Asa
Old Nov 20, 2022 | 06:24 PM
Sparky04SD's Avatar
Sparky04SD
Lot depends on engine/transmission and axle gearing. What is tongue weight of trailer and total weight of trailer and 47 Ford on it?
Old Nov 21, 2022 | 04:11 PM
senix's Avatar
senix
think we need to know HP and TQ numbers and the weight of the trailer empty and the weight of the 47 Ford.
Old Nov 27, 2022 | 12:05 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
. . . and what kind of roads are you towing on (Interstate, local, dirt, etc.?) and how far are you towing?
Old Nov 27, 2022 | 05:29 PM
FuzzFace2's Avatar
FuzzFace2
Anything pulling the weight of a trailer that can carry a older heavy truck and older heavy truck better have a frame mounted hitch and be setup with electric brakes.
As asked answer the other questions as it will help us help you.
My 81 F100 flare side with a 300 six, NP435 (granny first) and over drive that I can split all the gears and 2.75 rear gear (not the best for towing) is back up to pull my open deck 20' car trailer.
It dose have a frame mounted hitch and electric brakes for when the time comes.
I am sure it will get the job done just not fast. The 300 & granny first transmission has been used in larger trucks.
Dave ----
Old Nov 27, 2022 | 06:11 PM
351Cleveland C4's Avatar
351Cleveland C4
Let's estimate that the 47 on a car trailer will weigh 6,000 pounds.
At minimum, That requires a receiver hitch, and trailer brake controller.
As for the rest of it, there's a lot that makes a "good" tow vehicle. And you haven't told us anything about this 52....
ptt87
Oct 29, 2021 03:14 PM
02250sd
All Things Towing
Mar 31, 2021 11:36 PM
ttechnology
All Things Towing
Mar 18, 2020 07:53 PM
thebillsmith1
All Things Towing
Jul 16, 2004 10:32 AM
Eyerock
All Things Towing
Jan 20, 2004 04:42 PM
