Trans ID / swap
I don’t want granny gear and was wondering if this one has granny, can I have someone replace the gears so its a 4 speed 4:1
Any idea of what the trans is out of?
If it does have a "granny" low gear, it's doubtful you'd be able to install a "taller" gear set to get rid of the super low first.
You did say it is a 4x4 how will it be used?
Weekend cruiser to crush paper cups or a mudd bogger?
Any old school trans you find will be 1 to 1, 4th gear, not over drive.
I dont know of any older 4 speed truck trans that dose not have a granny first gear?
What gear ratios are in the axles?
Dave ----
Drove 66 passenger school bus, 366 with 5 speed, had granny 1st too.
I very rarely used granny, but was sure nice when needed.
that picture is a 77 150 4wd with a manual reverse shift down not up.
it was sitting in a mud hole so thats the only picture I could get lol
its 22 degrees in East Tennessee
I appreciate the help
Dave ----
Its gonna be a weekend trip truck but lifted, divorced and lockers installed
I have a bell housing and adapter for the transfer case , been talking to a guy who has a 4:1 4 speed but he wants 1700 bucks
dont know about the gears, can’t find anything that tells me, I did call Ford to get a build sheet tho
not sure if its a Ford or Borg but was told there were some used in Ford dump trucks
https://www.ford-trucks.com/forums/1...l#post20634436
IMO it's a miserable transmission due to the big gap between 2nd and 3rd. Depending on gearing, and with a 400 in front of it, that might be tolerable. But a 5 speed would be better. That 4 speed OD was never offered in anything beyond an F or E 150. It is not a strong truck transmission, but rather a modified car transmission.
a few people have told me to stay away from the 5 speeds due to them being too light for the horsepower but my helper said today that there were some that could handle it in the F250
If you were doing it, what would you use?
The motor will be making around 500-600hp
I would never use a any of the 3sp+OD transmissions as they are too weak and hard to get parts for.
The M5OD (1988>) is used in F250 trucks with 351's just watch as the later ones dont have speedo cable holes.
But then you say "adapter for the transfer case"?
I know the T18 & NP435 dont shift fast as they are a truck transmission and the gap between 2 & 3 a little big but they are strong and you can get parts for them. Unless you need the garnny first for heavy loads you drive them as 3sp transmissions.
If you want over drive with the T18 / NP435 look at Gear Vender's unit and you might be able to split 2nd gear before shifting to 3rd direct.
I do that with my NP435 and Advance Adapder's Range Spliter.
Dave ----
The M5OD (1988>
is used in F250 trucks with 351's just watch as the later ones dont have speedo cable holes.Is the transfer case "divorced"? If so then you are looking for a 4x2 transmission.
Dave ----
Its gonna be a complete restoration project so I have time
I’m almost done with my Daughters 78 F250 so I’m trying to gather good information while the motors is going through the shop and be ready as the weather allows
I found a 435 4 speed thats maybe worth using
400 bucks
