2018 SD Wipers only on high, washer doesn't work
Old Nov 15, 2022 | 12:28 AM
Parson Tim's Avatar
Parson Tim
2nd Gear
2018 Superduty the wipers only work on high and the windshield washer pump does not work. I read here somewhere that if the wipers return to the off position after the are shut off, that it probably is not the motor. I changed the wiper control on the column and no change. So I changed the motor (used one from reputable source, Ford says they can't get them) still no change. What might I be missing? Any help would be sincerely appreciated!!!!
Old Nov 15, 2022 | 05:17 AM
senix's Avatar
senix
My first thought was the turn signal/wiper control on the steering column. Looks like you did that.
Have you scanned for any possible codes? did you check for any recalls on the blades?
Old Nov 15, 2022 | 10:40 AM
Parson Tim's Avatar
Parson Tim
2nd Gear
Will check for codes. No recall that I am aware of. No recall shown by Ford. Thanks for your help!!
SproutW
1978 - 1996 Big Bronco
Feb 20, 2008 11:12 AM
rkeziah
Nov 9, 2006 05:26 PM
1fordsoldier
May 14, 2006 11:17 AM
tommowry
Dec 18, 2003 04:06 PM
