Dana 60 questions
Old Nov 13, 2022 | 07:33 PM
Harveyearlolstad's Avatar
Harveyearlolstad
Dana 60 questions
Hi all, got a 97 f350 cclb powerstroke. And I started pulling apart my hub/Axel/spindel assembly to get to my ball joints to replace. I have been experiencing grinding noises while turning especially at low speeds. But when taking apart my hub assembly I noticed no snap ring. Also both my axels have as little back and fourth play. Is that normal? I would imagine the snap rings would keep the movement from happening but my Axel has no groove in it for a snap ring to seat. Please respond, thanks.
Old Nov 28, 2022 | 02:52 PM
knottyrope's Avatar
knottyrope
no snap ring on my axle shaft when I took it apart
if ball joints are really bad, then unjoint cant turn correctly and maybe you source of noise
Old Nov 28, 2022 | 03:04 PM
Harveyearlolstad
The noise occurs when in 2wd so I wouldn't think the Axel is the issue?. I put new ball joints in on the left side where I think the noise is coming from. I also replaced all tie rod ends and steering linkage all the way to the pitman arm. I test drove it yesterday and still can hear the noise. Either the bearings are making the noise or it's the right side which I haven't done yet. Sometimes noises can be hard to track where they come from? When I disassembled the hub/bearing components everything looked ok and freely spun easily. It's possible that when I pull apart the right wheel I might be able to notice difference between the 2 sides. The noise occurs only when turning left and sounds like it comes from the driver side. I chose to replace these parts because they had obvious wear to them.
Old Nov 28, 2022 | 03:08 PM
Harveyearlolstad
I pulled the left Axel shaft and the u joints were not seized or had any play in them when holding both ends. I debated on getting the u joints replaced at 100 each Axel shaft considering I had everything pulled apart but I elected to save the money.
Old Mar 17, 2023 | 02:03 PM
Harveyearlolstad
I replaced the ball joints, and all steering parts to the drop pitman arm. I then took it to get aligned. The guy at the alignment shop stated it could be the tires rubbing when turning left. But my tires are 33's on a one ton truck and I doubt just by looking at my wheels while they are turning that this is happening. I also see no wear markings. Could it be the steering box? Could the steering box be getting jammed up only when turning left?
Old Mar 19, 2023 | 01:55 PM
mark a.'s Avatar
mark a.
When it's doing this can you feel the noise in the steering wheel ?
Did it just start doing this one day or was some work done on it then it started ?
Old Mar 19, 2023 | 02:06 PM
Harveyearlolstad
Don't feel it in the steering wheel. Going faster speeds turning there is not noise. It's only during sharp turns. But then again, who makes sharp turns going freeway speeds. It's been occurring since I bought the truck a year and a half two years ago. I pulled the front axle and bearings apart on both Wheels replacing the ball joints. I inspected the u-joints on the front axles on both Wheels and they weren't seized or they didn't even have excessive play so I left them as is. Then I replaced the tie rods all the way up to the pitman arm. I can't imagine the issue being the u-joints because these noises don't occur while driving just four wheel. The only thing I can think of is the steering box. Tires rubbing would be an obvious and noticeable sign. Could the leaf springs be making this noise but I doubt it? The noise sounds like coming from the left side while only turning left
Old Mar 19, 2023 | 02:11 PM
Harveyearlolstad
Could it be bearings? I didn't replace the inner or outer bearings but if it were bearings I'd be hearing the noise regardless of turning.
Old Mar 20, 2023 | 09:19 AM
mark a.'s Avatar
mark a.
When It starts making the noise does stepping on the brakes stop the noise ?
Old Mar 20, 2023 | 09:26 AM
Harveyearlolstad
I don't think so. I can verify that. But when I start turning the wheel the noise begins at a certain point while increasing the turn. And when I say increase meaning the more I turn the wheel. In other words, the noise begins at a certain turn radius and continue as I turn further. That's likely why I don't hear it at larger speeds because the turn radius is not enough to engage that noise. I hear it at stop light turns around my neighbor when turning down the street and such. But not in the highway.
Old Mar 22, 2023 | 09:12 AM
mark a.'s Avatar
mark a.
If the brakes don't stop it my next step would be putting it up on jack stands, start it up and turn the wheels in the direction it makes the noise and go from there.
Old Mar 22, 2023 | 09:54 AM
Harveyearlolstad
I will do. I will report back with my findings.
Vasq1
Jun 1, 2021 08:12 PM
JustinP
Sep 3, 2015 02:53 PM
X36
Oct 14, 2007 09:39 PM
Stroker_Deezel
Offroad & 4x4
May 29, 2005 01:32 AM
