Ignition Gremlin
Old Nov 12, 2022 | 11:40 AM
LiquidCowboy's Avatar
LiquidCowboy
Ignition Gremlin
Ok so to preface this its a 1972 429. Replaced Petronix Ignitor unit with the Ignitor II after the magnetic wheel failed.
the issue is.... at a cruise when wanting to go up a hill its wanting to cut ignition. Ill checking gap shortly when we slow down at work but Petronix states .010-.060 is working range for air gap factor. and it only does it at highway speed. 1st or 2nd gear no issues. in 3rd going up and out of mountains its fine just at highway cruise like vac advance is pulling the unit too far. can the dizzy springs not pull it back?
Old Nov 13, 2022 | 12:01 PM
manicmechanic007's Avatar
manicmechanic007
You had me at Petronix
If you had a Duraspark or God forbid even a HEI you would not have any? trouble?
The vacuum advance spring is pretty tough / tight
So if your breaker plate in that distributor is sticking you need to deal with that issue first
That is what used to happen to those old point distributors
They would get some shaft wear and wear out the breaker plate bushing
Old Nov 13, 2022 | 01:12 PM
LiquidCowboy
i didnt even think about the breaker plate. ill look into it. might have a spare dizzy somewhere
Old Feb 12, 2023 | 12:03 PM
LiquidCowboy
Wow this thing is peppered! Picked up new dizzy (dual vac) under warranty for my 400 (should work I'll recurve if needed)
Old Dec 3, 2023 | 02:58 PM
LiquidCowboy
so ive fought this all year and found the issue was multi faceted. the petronix had de magnetized AND the fuel pump was going out so i was sucking the bowls dry. problem is finally solved!
Old Dec 4, 2023 | 07:04 AM
manicmechanic007
Absolutely wonderful
A very nice feeling indeed having figured it out
Happy motoring for a while now
Calls for a toast! Make mine a double
turpentyne
60
Nov 14, 2018 07:17 AM
mdbbrown
13
May 13, 2017 08:03 PM
Drag68Bird
1983 - 2012 Ranger & B-Series
Nov 24, 2007 04:37 PM
wally2117
Sep 30, 2002 03:34 AM
