The tie rod that holds the vertical vanes of the right end AC dash vent fell off. I see replacement vent units for $20. How do I remove the vent unit for replacement?
They can be a tiny bit tricky but buy the replacement, look it over and it should be easy to see the easiest way to remove the existing part. $20 each is a good price, I've seen them on eBay used for upwards of $40 or more.
I've yanked them out but if you're trying to re-use it that's not the best procedure.
