Argh!!!
Old Nov 10, 2022 | 04:25 PM
1ole4d's Avatar
1ole4d
Argh!!!
So I have this annoying check engine light yelling at me with a code 32with KOEO. I've checked all of the vacuum lines, replaced the egr position sensor and checked the egr tube for cracks and such. The engine light will flash when I'm accelerating or cruising down the interstate but nothing at idle. It runs fine but seeing the light flash and knowing it's throwing a code is driving me up the wall. I'm going to be swapping the motor out but everything on the top end is just going to be swapped over so I want to get this fixed now before I do the swap. Any ideas short of replacing the egr valve? It seems to me if it were the valve itself the light would come on and stay on, not flash.
Old Nov 10, 2022 | 05:17 PM
Conanski's Avatar
Conanski
Could be the computer itself, when was it last inspected? Also don't overlook the possibility of wiring damage... that gets more likely the older a vehicle gets.
Old Nov 10, 2022 | 05:51 PM
rla2005's Avatar
rla2005
Code 32 (KOEO/KOER)EVP circuit below minimum voltage of 0.24 volts.
The EGR valve diaphragm/spring may have collapsed. Check the EVP sensor feedback output KOEO to verify it is in range. Typical is 0.24 to 0.67 VDC. If you are on the low end it could be the EGR valve as mentioned or the EVP sensor. It's tough to decipher which one since the EGR valve preloads the EVP sensor.
Old Nov 10, 2022 | 06:17 PM
1ole4d's Avatar
1ole4d
I had the ecm out last year. It's a remaned unit from Cardone. I found a replacement pigtail for the pressure sensor. I'll test the wiring and see what I find. Would be nice if it was just a simple wiring issue. Don't really want to spend the money on a new valve. Unless it's needed obviously.
Old Nov 11, 2022 | 11:28 AM
1ole4d's Avatar
1ole4d
I just checked and it's right at .45v koeo and .49v at idle. Also the 5v reference signal is there. The vacuum lines are all ok.
Update: Just went to the store and the check engine light never flickered or came on. Makes me think there was just a loose connection somewhere. Hopefully that was it.
octaneforce
Aug 23, 2012 11:54 AM
metal7654
1997 - 2003 F150
May 22, 2010 12:17 AM
boogie
1997 - 2003 F150
Mar 12, 2010 03:25 AM
vozizm
Oct 11, 2006 06:19 PM
breedlrs
Jan 20, 2004 05:41 PM
