Egr Valve
Old Oct 10, 2006 | 06:08 AM
vozizm's Avatar
vozizm
Egr Valve
Hola.. yes i tried the search feature!!
A little background.. I got this 00 expy new in 00 sold it to my bro-inlaw in 03 just flew up to NYC to get it saturday.. bro said check engine light was on ..so he took it to a shop in ny and they said it coded egr.. so the fella cleans the valve and the light goes out but comes back on in 2 days he takes it back... picks it up and light is off... kewl right!!
I take it to get state inspection today.. it coded egr again.. and check engine light does not work anymore...
QUESTIONS!!
could i try and get over by removing and cleaning all egr realted hoses, lines and hardware? I know that clogged hoses and lines will still code egr if egr is replaced and hoses are clogged or dirty..
or should my cheap *** just replace them?
I am not going to a stealersgip.. so which online source do you suggest?
Thank You!!
Old Oct 10, 2006 | 07:37 AM
projectSHO89's Avatar
projectSHO89
Get the actual fault code and use the SEARCH feature with the actual code as yuor keyword.
EGR valves seldom fail. Don't waste any mony on one until it is proven defective.
Steve
Old Oct 10, 2006 | 09:18 AM
Freak4Ford's Avatar
Freak4Ford
I had a problem with the EGR valve causing the check engine light to come on. I inspected it was pretty much clear. The problem was the tube was clogged with carbon. After several attempts to clear it, I found it was better and time saving just to replace the tube. No more codes after the tube was replaced.
Old Oct 11, 2006 | 07:13 AM
vozizm's Avatar
vozizm
Thanks Fellas!!!
Old Oct 11, 2006 | 06:19 PM
vozizm's Avatar
vozizm
changed egr and cleaned out those 2 rubber hosesand metal pipe that goes from egr to manifold.. and it still codes
i will try and buy the metel pipe and get new hoses!!..
I will also run some seafoam through it!!
i am hardheaded i guess!
