fuel gauge stuck on empty
Old May 7, 2006 | 09:50 AM
james gang 1001's Avatar
james gang 1001
No matter what tank I switch to my fuel gauge does not work. Can I touch the two wires going to the tank sending unit together to see if the gauge moves, and if it does wouldnt that mean its the sending unit? What else could I check? Oh yeah its a 75 F150
Old May 7, 2006 | 02:35 PM
LxMan1's Avatar
LxMan1
You should be able to ground the hot wire to the sending unit should send it to full.
Old May 7, 2006 | 02:58 PM
james gang 1001
the gauge and the wiring is good . the sending unit is on the side of the aux tank , is it just threaded in, it also has the fuel line coming out the same spot
Old May 8, 2006 | 02:13 PM
LxMan1's Avatar
LxMan1
Sounds like either the float has a hole in it or the float has fallen off of the arm.
rdpickett406
1978 - 1996 Big Bronco
Jan 23, 2015 08:29 PM
OldgreenF1
Feb 26, 2007 02:11 PM
uk1050
Feb 17, 2006 12:21 PM
Manwith3fords
Sep 30, 2003 02:12 AM
