AIR INTAKE SENSOR... HELP!!!
Old Nov 6, 2022 | 10:00 PM
jb1357's Avatar
jb1357
6th Gear
HELP... Not sure if I'm at the right spot for this but I've got a f250 6.0 diesel turbo powerstroke & & got a code that my air intake sensor was not good so I took it out cleaned it up & put everything back together. Now I'm blowing grey black exhaust which I would think is a sign that my air to fuel ratio is wrong. Where do I go from here? I didn't have the excessive exhaust before. Should I check & clean the mas air sensor? UHG... I'm just a beginner in all of this...
Old Nov 7, 2022 | 04:55 AM
bismic's Avatar
bismic
Which Intake Air Sensor did you clean?
What was the code number?
Old Nov 7, 2022 | 08:08 AM
jb1357's Avatar
jb1357
6th Gear
The code was 113 & I cleaned the IAT sensor located right underneath the hard air hose.
Old Nov 7, 2022 | 08:28 AM
bismic's Avatar
bismic
You cleaned IAT2.
P0113 is for IAT1, which is part of the MAF sensor.
Old Nov 8, 2022 | 01:16 PM
jb1357's Avatar
jb1357
6th Gear
I cleaned the MAF sensor but it's still blowing grey black exhaust. I'm starting to think I've maybe got a bad injector...
Old Nov 8, 2022 | 03:57 PM
bismic's Avatar
bismic
P0113 (Common to have this code if the MAF is disconnected with the key on); IAT1 sensor output above expected sensor range:
(IAT1 wiring are the outer two wires (one on each side) on the MAF connector)
  • Faulty Intake Air Temperature (IAT1) Sensor
  • IAT1 Sensor harness is open or shorted
  • IAT1 Sensor circuit poor electrical connection
  • Dirty Air Filter
  • Faulty Powertrain Control Module (PCM)
Danny2016
May 12, 2021 02:50 PM
xaviar
Aug 16, 2013 09:17 PM
nycstev
Mar 2, 2013 05:02 PM
ngng
Mar 17, 2009 07:58 PM
Trevor1
Aug 24, 2008 10:07 AM
