Pull Engine or Not?
Old Nov 8, 2022 | 02:00 PM
5851a's Avatar
5851a
No need for hi volume oil pump for normal driving. Oil pumps are the most lubricated part in the engine. A regular replacement would be fine, doubt the old one is bad unless it sucked in some junk. Try some heavier oil as temporary. Maybe do a full rebuild over winter. Don't buy parts ahead of what is needed by machine shop/rebuilder. Rubber core plugs can be a life saver but should be considered as a temp fix. OT but, there was an old man in my hometown, when I was a kid in the 50's, he drove a Model T roadster pickup that looked new. My Grandfather told me he put it away every winter and pulled the engine to get it ready for summer. A bit extreme for dent side era, but maybe once every 45 or 50 years for a tear down sounds about right.
Old Nov 8, 2022 | 04:10 PM
flowney's Avatar
flowney
Beware the slippery slope. STP and/or heavier oil will set your mind at ease w/o getting anywhere near that slope.
Old Nov 8, 2022 | 04:19 PM
tbear853's Avatar
tbear853
"While I'm here ........"
Old Nov 8, 2022 | 07:23 PM
bulletpruf's Avatar
bulletpruf
Originally Posted by Mark8man
When you pull an engine with high miles and age, the snowball effect is very difficult to avoid and starts a chain reaction of sometimes frustrating and costly events. DON'T PULL IT until you are prepared financially and mentally for the total rebuild.
Reminds me of the time I pulled my 1970 Ram Air IV GTO in the garage for a tuneup and brakes. As a result of said snowball effect, I had the body off the frame a few weeks later, followed by a full concours nut-and-bolt restoration. Car won Concours Best Restored at 2013 GTOAA Nationals, ended up in a few magazines, etc. And it all started with a brake job and tune-up...
Old Nov 8, 2022 | 07:53 PM
Tiggie's Avatar
Tiggie
Thanks for the input everyone.
I more permanently installed the real oil pressure gauge so I can see what it's doing in action.
Old Nov 9, 2022 | 12:08 PM
redroad's Avatar
redroad
I agree 100% on the oil pump in the case of a stock motor but if you add any additional oil volume like an external oil cooler, larger volume oil pan, or externally mounted double oil filter etc. then an HV oil pump is needed. So if you have future plans for any of these now's the time to do it. On a working truck these add-ons are almost a requirement if you want your motor to last.
BHosey3875
Dec 18, 2019 08:02 PM
jimsville
15
Sep 26, 2006 09:53 PM
Roamineye
Jul 14, 2006 10:43 PM
siphor84
Oil & Lubrication
Sep 29, 2003 03:20 AM
CrazyFordMan
Mar 20, 2003 08:31 PM
