Modular V10 (6.8l)
Weird Electrical Anomaly.
Old Nov 3, 2022 | 08:08 PM
F-250SnowKiller's Avatar
F-250SnowKiller
8th Gear
Every so often the battery light will come on then go off. Seems RPM related as higher RPM will sometimes result in light coming on.
Also, possibly related sometimes it will lose all interior power. All lights go out, dash goes dark, gauges go to zero. Just like the key was turned off. Then gauges will cycle through full deflection and everything goes back to normal like key was turned on again. Headlights, engine etc stay on.
I'm thinking there is a bad ground somewhere, like maybe engine ground strap?
Just looking for some thoughts on where to start looking.
Old Nov 3, 2022 | 08:50 PM
GOT-DRT's Avatar
GOT-DRT
My econoline did the same thing and it ended up being the alternator
Old Nov 3, 2022 | 09:29 PM
F-250SnowKiller
8th Gear
Thanks for the response. I guess I'll have to test the alternator.
Old Nov 4, 2022 | 06:54 AM
projectSHO89's Avatar
projectSHO89
Two separate problems:
1. The brushes in the alternator are wearing out and "floating" at higher RPMS. Time for a new alternator.
2. Probable intermittent connection in a circuit that feeds the affected items. Might be a failing switch, fuse holder, or connection.
Old Nov 4, 2022 | 08:16 AM
F-250SnowKiller
8th Gear
Makes sense.Thank you.
aluckylady
Escape & Escape Hybrid
Aug 29, 2021 12:29 PM
warren3527
Nov 27, 2012 02:13 PM
Alto
1983 - 2012 Ranger & B-Series
Jun 26, 2012 10:32 AM
mbolte
Nov 25, 2011 06:54 PM
messeswithtrux
17
Mar 3, 2010 04:35 PM
