New here and need some input!
Old Nov 2, 2022 | 10:01 AM
Jonathan Perkins's Avatar
Jonathan Perkins
5th Gear
I just bought my first powerstroke a 2017 F250. The airbag light and steering wheel controls didn't work when I bought it, I changed the clock spring now e erything works except the cruise control. I replaced the brake switch, checked the number 31 5amp fuse under the hood and last night I changed the steering wheel controls. It still won't turn on? Any ideas? Any help is appreciated..thank you
Old Nov 2, 2022 | 01:14 PM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE !
Exactly what happens when you press the ON button on your steering wheel?
Old Nov 2, 2022 | 01:16 PM
redford's Avatar
redford
Oh, also, do you have normal or adaptive cruise control?
Old Nov 2, 2022 | 01:17 PM
Jonathan Perkins
5th Gear
Nothing, at all. The dash light to show the cruise control is turned on doesn't come on and it doesn't work
Jonathan Perkins
5th Gear
It's normal cruise control..
there is one weird thing that happens, when I press the mute button it activates the voice control and when i press the voice control button nothing happens.
Old Nov 2, 2022 | 04:32 PM
T. Banning's Avatar
T. Banning
You might check and make sure you don’t have a bent pin in any of the harness connections.
Old Nov 2, 2022 | 07:19 PM
Jonathan Perkins
5th Gear
I called the dealership I ordered the clock spring from and they said it's not uncommon to get a bad clockspring?
Old Nov 3, 2022 | 08:00 PM
Jonathan Perkins
5th Gear
I took the steering wheel off and took the clock spring off, checked everything and reinstalled it all. It is still doing the same thing: no cruise control and when I press the mute button the voice control comes on....?
Old Nov 3, 2022 | 08:13 PM
SasquatchNM's Avatar
SasquatchNM
You might check the current draw from the flux capacitor. Any resistance not built into the design could be disastrous.
Old Nov 4, 2022 | 08:22 AM
F250 Bushman's Avatar
F250 Bushman
Probably has a bad muffler bearing. I'd change that out and see if that fixes your problem.
defonic
Jan 11, 2024 10:33 AM
defonic
Nov 7, 2021 06:13 PM
kt19
6.7L Power Stroke Diesel
May 2, 2017 10:21 AM
kelwar
Mar 30, 2009 11:21 PM
nwajetmech
1997 - 2003 F150
Mar 13, 2004 07:16 PM
