Poll on "shocks"
Old Nov 2, 2022 | 05:31 AM
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by Y2KW57
Talk about shocks!
I thought Halloween was over last night.
Shocking price for what started as a bmx bike shock. I remember riding downhill on a bike with a Fox shock in 1975. State of the art bike (wasn't mine).
I'm shocked that these bike shocks now cost so much, but am impressed at how the company transformed itself into brand that can command such a high premium for their products.
I know what you mean. I was skeptical at first because that is how I remembered the brand too. I decided to take the plunge after much research indicated that they are the real deal with comparisons made to King shocks even. King is the brand to look at if you want breathtaking prices.
https://www.filthymotorsports.com/Ki...-superduty.htm
Old Nov 2, 2022 | 05:39 AM
FordTruckNoob
Originally Posted by beachcamperf250
I have no complaints with my Rancho 9000 adjustable shocks, make sure and use good grease on the **** when you get them and they are good to go, mine are over 7 years old and still work great. I haul a 5000lb truck camper on the back so they get plenty of use. I set my rear ones at 9 and adjust them down to 5 when the camper is off, I leave the front ones set at 5.
Originally Posted by aawlberninf350
Another vote for the adjustable. If you use your truck empty and loaded dial in your current pleasure.
X2 grease the ****. Also hit them with cheap clear coat before install and no worries on surface rust.
I learned that lesson the hard way on my first set of 9000s. Went to adjust the damping one Spring morning and the **** snapped off in my hand. The second set saw the ***** removed and the cavity packed with grease before the shocks were installed on the truck.
Old Nov 2, 2022 | 08:09 AM
JimmyWayne23's Avatar
JimmyWayne23
Bilstein 5100s here, stock height truck but going to bump up to 33s eventually. Bilsteins we’re a huge improvement over my blown factory shocks
Old Nov 2, 2022 | 09:23 AM
FinnishStroker's Avatar
FinnishStroker
I have had good experience with KYB and Gabriel monotubes.
Spend far less money than with Rancho or Bilstein.
Overall If person likes firmer ride,monotubes are the way to go.
Twintubes(OEM type) for smoother ride.
Old Nov 2, 2022 | 09:50 AM
liquidlounge's Avatar
liquidlounge
I have found mono tubes tend to ride close to the same at all times while twin tubes can be smoother when cool, but tend to ride awful when heated up.
Old Nov 2, 2022 | 11:46 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Rancho 9000s, that I had previously... rust within a few months of installation.
Rancho Shocks.
Rauncho Finish.
Old Nov 7, 2022 | 10:00 AM
Josh Ross's Avatar
Josh Ross
Diverdude
Bilsteins
Plus one for bilsteins.
Old Nov 7, 2022 | 02:16 PM
SteveH-CO's Avatar
SteveH-CO
KYB Monomax from Rock Auto. Price-competitive and stiffer/stouter than KYB Gas-adjusts, which I put on my other vehicles.
Old Nov 9, 2022 | 08:56 AM
MARCSPSD's Avatar
MARCSPSD
Bilstein here 2001 Ex PSD 4x4 stock height
Super long lasting. Could not make up my mind so I used 5100 on front axle and 4600 on rear. Both holding up well. S Fl truck so no salt.
Fine shock for a pavement queen. For offroad IDK.
BenEck
Jun 30, 2023 10:49 PM
1L243
Aug 11, 2013 01:42 PM
t_lcohen
1997 - 2003 F150
Oct 1, 2006 01:09 PM
EGPD1725
Oct 22, 2004 08:51 AM
fordmudrunner2020
15
Apr 30, 2003 10:27 PM
