shocks
Old Jul 10, 2022 | 08:46 PM
BenEck's Avatar
BenEck
5th Gear
shocks
Thanks for every ones help. I am going to replace my shocks on my 2003 Excursion. Any suggestions on brand, model, etc? I do pull a travel trailer but other than that it is just normal usage.
Thanks again!
Old Jul 10, 2022 | 09:58 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by BenEck
.... I am going to replace my shocks on my 2003 Excursion. Any suggestions on brand, model, etc? I do pull a travel trailer but other than that it is just normal usage.....
2wd or 4wd?
The Bilstein B6 4600 shocks I installed awhile ago are nice, but they have gone up quite a bit.
Old Jul 11, 2022 | 06:41 AM
BenEck's Avatar
BenEck
5th Gear
Its the 4wd.
Old Jul 11, 2022 | 08:06 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
I second that for Bilstein 4600s. I’m on my fourth set.
Old Jul 11, 2022 | 08:31 AM
R&T Babich's Avatar
R&T Babich
How many miles are you getting out of a set of the Bilsteins?
I have about 40k on ours and they still seem fine.
Old Jul 11, 2022 | 11:40 PM
ASFC27FTFBQ
I average around 53,000 miles per set.
Did some math and that’s what I came up with.
Old Jul 12, 2022 | 09:21 AM
EXSwap's Avatar
EXSwap
Stock ride height?
For me, the KYB Monomax was awesome. Great ride and I ran them 100K before replacing. I think only one was really bad at that point.
Now I'm ~4" over stock ride height and run the bilsteins. It's a little rougher than I like, but still a decent ride.
Old Jul 12, 2022 | 12:23 PM
bwguardian's Avatar
bwguardian
I run the Monroe gas units on my 4wd F350 and like them. You can get them at your local parts store and they have a life time warranty...which I have utilized a couple years ago as the originals were installed somewhere around 2004! The only thing I don't like about them is they are yellow, so I spray them with gray bedliner material prior to installation which does not affect the warranty btw...
Old Jul 12, 2022 | 12:43 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Thanks again!
which shock you will like is subjective but in general a mono tube ( bilstein) shock is more durable than a twin tube ( rancho )
the larger the tire you run the more valving you are going to want.
for stock-ish size tires the KYB Mono Max is hard to beat. Oversize tires the Bilstein 5100 is popular
Old Jul 12, 2022 | 01:34 PM
Summitracing's Avatar
Summitracing
SPONSOR
OP,
You can't go wrong with Bilstein 4600's or KYB MonoMax shocks. These are both gas-charged monotube shocks that fit a 2003 4WD Excursion with the stock ride height.
For an OE-like feel check out the Monroe Monro-Matic Plus shocks. These are gas-charged twin-tube shocks.
As other members have stated a lot about selecting shocks is the feel/ride you're after. Here's a chart we put together comparing monotube shocks to twin-tube shocks.
Let us know if we can be of any further assistance. We'll be happy to help!
__________________
800-230-3030
www.Summitracing.com
Old Jul 12, 2022 | 07:43 PM
02ExFilo's Avatar
02ExFilo
I just bought some KYB monotube hope it was a good choice
Old Jul 18, 2022 | 11:37 AM
Gunnie357's Avatar
Gunnie357
Trailering
Really happy with the Bilsteins on mine
Old Jul 29, 2022 | 09:27 PM
hambass's Avatar
hambass
Bump
From opinions on here, several years back I bought the KYB MonoMax's and I can't stand the ride.
They turned my 2003 V10 4WD into a rattle box.I hate driving the truck and I'm tired of apologizing to passengers, so I don't drive it too often. I've only put a couple thousand miles on them hoping they would loosen up, but nope, still hate them.
I want the smooth factory ride, I don't off-road. Stock height and wheel size.
Any other thoughts?
Old Jul 29, 2022 | 09:58 PM
hambass's Avatar
hambass
Could there be a difference in ride between the stock/Eddie Bauer/Limited editions?
Mine is the Eddie Bauer - it's just never made sense to me that the recommended shock rides so rough on my truck.
Old Jul 29, 2022 | 11:23 PM
02ExFilo's Avatar
02ExFilo
I did KYB Gas-Adjust thought about monomax but i wanted to try and maintain a smooth ride these seemed better for that. the old ones were old and shot can defiantly tell there are new ones
