I'm stumped hoping some of you can point to the fix. Read dozens of posts on various Web Forums and FB groups on the issue and seem to reading a magnitude of recommendations.
03' F350. I have no low end acceleration. Push the pedal down but it just does not have the get up and go it used to have. It's throwing a P1247 Code, (Tubo Boost Pressure Low)
Things that have been done recently, New Up Pipes, New exhaust, new tranny. Replaced the EBP and Tube. Replaced EBPV. (2) injectors replaced a year ago. No exhaust leaks coming into the turbo. No leaks on any boots. Has oil.
I have Forscan so what sensors should I set up on it to post back to these groups to narrow down the problem? Other recommendations to look for now. This is a truck we need to get back into service. Cheers and thanks for any helpful info.
Check the hose between the MAP sensor and the intake spider - make sure it's intact and gently sloping from MAP sensor to intake. If it has a dip in it, it can trap oil and mess with the reading.
Monitor MAP and MGP (manifold gauge pressure, or boost) and see what they show during a spirited drive. On a stock 7.3L, MGP should play around 17-18psi at WOT.
While you're at it, monitor ICP and IPR% for their values at idle and WOT. I monitor several of these PIDs since it's pretty easy to set up. See the link below for a how-to with FORScan:
I would also have a look at your fuel pressure. Since the PCM has no way to monitor fuel, a low pressure problem can present with seemingly unrelated codes.
Visual or pressure tested? Boost leaks can prove to be tricky to locate even with the pressure test. I pressure tested 3 times before finding the plenum leak.
Here is an example of a “good” test.
7.3 Powerstroke Good Boost Leak Test Reference
