P1247 Code
Old Nov 26, 2011 | 07:28 AM
koski19's Avatar
koski19
P1247 Code
In the last 6 months a P1247 was set twice under the following conditions. Once when pulling a horse trailer up hill, cleared code and three months later, yesterday while the truck was empty and going up an incline to get on the freeway. P1247 is a low boost code.
I've installed a new up pipe (old one was rusted out) 4 months ago and a big head actuator from Banks (6 months ago). I hauled the 10' cabover camper in August (4500 miles) without the code being set.
If your truck has set the P1247 code. Where did you find the problem to be and what was the remedy to fix?
I've tightened down the boots and they look in good shape. Could the Big Head Actuator be out of adjustment?
jeff
Early 1999 F250 SD 7.3
4R100 6637, HPX mods
Old Nov 26, 2011 | 08:15 AM
mueckster's Avatar
mueckster
Leaking uppipes are another cause of low boost. Have you looked around the connections for soot? Also, you could have a bad MAP sensor that may be reading
incorrectly.
Old Nov 26, 2011 | 02:42 PM
koski19's Avatar
koski19
I'll take a look at the uppipes. Are the uppipes another name for the Y-pipe?...Thanks for the info
Old Nov 26, 2011 | 02:50 PM
mueckster's Avatar
mueckster
Pipes from exhaust manifolds to Y-pipe, commonly called "baby's butt''.
jcmagone
Jan 3, 2024 08:16 AM
RigCity
Mar 10, 2017 11:27 AM
sweatthawg913
2015 - 2020 F150
Oct 28, 2016 08:04 PM
KevinC.
Jun 11, 2009 06:23 PM
Big Fish
Jun 1, 2007 04:23 PM
