Slip Yoke clunking
Old Oct 26, 2022 | 03:10 PM
SMW's Avatar
SMW
4th Gear
Slip Yoke clunking
I know there are other threads with this issue but I'm not sure all the "Clunking" noises people are describing are the same. I took a video today of the clunking my truck was making and found it to be the slip yoke. It clunks when stopping and when accelerating from the stop. It may be doing this while driving as well but i don't notice it. Any mechanics have a fix for this? Is this a simple take apart and grease job or am i looking at a more serious issue?
2019 F250 6.2L Gas
Old Oct 26, 2022 | 03:24 PM
scraprat's Avatar
scraprat
Top Answer: 5
I would start with greasing it. Eliminate that first.
Old Oct 26, 2022 | 03:49 PM
jimzpsd's Avatar
jimzpsd
Greasing it won't do a thing other than make a mess, (it is designed to get all the lube it needs from the atf, if your referring to the slip shaft ). I would check for severe axle wrap, caused by a loose axle u-bolt, missing leaf spring, motor/trans. mounts, etc. Looks very severe in my opinion.
Old Oct 27, 2022 | 12:09 PM
SMW's Avatar
SMW
4th Gear
Update to my previous post and video: Packed the splines of the slip joint with grease and fixed the issue.
Old Oct 27, 2022 | 12:54 PM
scraprat's Avatar
scraprat
Top Answer: 5
Good to hear. Start simple than full bore open heart surgery.
Old Dec 9, 2024 | 09:15 PM
TuckTruck427's Avatar
TuckTruck427
Trailering
How did you grease the slip joint? Can you just remove the driveshaft, then pull the yoke out? Will trans fluid come pouring out? My truck is definitely clunking like yours.
Old Dec 10, 2024 | 06:58 PM
longhaultransport's Avatar
longhaultransport
Drop the driveshaft from the rear and pull. Put a pan under the tailshaft to collect any fluid that might drain out.
Ford even sells a slip joint grease if you want to stay OEM.
Old Mar 17, 2025 | 01:54 PM
TuckTruck427
Trailering
I was experiencing the same clunking issue. The output shaft seal also starting leaking, so I went to Ford and bought the seal. Greasing the splines and replacing that seal were super easy and it fixed my clunking issue! I just used some high moly engine assembly grease I had on the shelf. The splines looked good and had ATF in them - not good enough apparently.
Old Mar 23, 2025 | 06:57 AM
morehouse7's Avatar
morehouse7
I just pulled and greased mine yesterday with the Ford grease, no clunking now.
Joe Finn
1997 - 2003 F150
Jan 18, 2007 07:39 AM
truckseeker
2004 - 2008 F150
Oct 23, 2006 07:33 PM
scottb1014
2004 - 2008 F150
175
Mar 1, 2006 11:48 PM
Forrest_F150
2004 - 2008 F150
Aug 12, 2005 09:46 AM
