piston ring help
Old Oct 25, 2022 | 01:42 PM
catastrophejustin's Avatar
catastrophejustin
piston ring help
hello i am new to the forum and after searching around a bit i had a question on piston rings that i cant seem to find an answer to. when buying .020" oversize rings are the .020 over the bore size in diameter or are the .020 wider then stock. Just picked up a 71 F100 and it was smoking quite a bit so i am looking in to rebuilding the motor. motor is a 390 and the pistons are stamped .020 on the top.
Old Oct 25, 2022 | 02:06 PM
gobc1954's Avatar
gobc1954
6th Gear
gobarron
An .020 piston ring goes on an .020 larger piston in an .020 larger bore. You would have to Check the piston Bores for Diameter and "out of roundness" and check the measurements of each bore.
If you want to gambol you could pop in a new set of .020 Rings because the rind do wear and it might buy some time. But if the Bores are out of round and Too Warn you would have to re-bore and re-oversize.
If the "smoke" is blue it is oil but if it is white it is water.
Old Oct 25, 2022 | 02:11 PM
catastrophejustin
Ok so it is not wider at all its the diameter that changes. thanks. i have heard of people running . 020 over on a stock size piston. thanks for the reply.
Old Oct 26, 2022 | 12:46 PM
smoky_diesel's Avatar
smoky_diesel
Check valve stem seals that may be most of smoking issue. but if you want a full rebuild that is another story. Good luck.
Old Oct 26, 2022 | 01:28 PM
catastrophejustin
Thanks. i will check them out. I will probably do a complete rebuild while i have already started taking it apart. timing chain had about an inch of play in it. i am surprised it even ran as good as it did.
RxRF250
Dec 10, 2020 07:32 PM
RxRF250
Dec 10, 2020 06:18 PM
Uncle Grumpy
Mar 13, 2012 07:25 AM
jade79
Nov 14, 2009 05:24 PM
dogsniper
Apr 29, 2007 01:29 AM
