Hypereutectic Pistons???
Old Apr 26, 2007 | 11:25 PM
dogsniper's Avatar
dogsniper
What does anybody think of hypereutectic pistons have you used them? some say they are to brittle is this right?
Old Apr 26, 2007 | 11:30 PM
hoxiii's Avatar
hoxiii
there are two peculiarities about them. first, you MUST set the ring gaps to what the piston manufacturer recommends. If you don't, you'll seize a piston in no time.
secondly, if the motor detonates hypereutectic pistons are more prone to crack or shatter than forged or stock cast pistons. They're also more prone to crack if the motor is overheated.
but at the same time, hypereutectic pistons provide for better ring sealing, less blow by, and can take revs better than a plain cast piston while being lighter than a forged piston.
I'm running a set in a 300-6 I have and I have no complaints about them at all.
Justin
Old Apr 27, 2007 | 04:25 AM
baddad457's Avatar
baddad457
I've run em in a hot 302 build up and with daily revs to 7500, had no problems with em. The block gave up before the pistons did.
Old Apr 29, 2007 | 01:29 AM
jstandle's Avatar
jstandle
From what the machine shop told me, the gap was wider on the top ring because it's higher up on the piston than the stock rings, if I remember right. I'm running a set in my 390. The machine shop I used is very knowledgeable on the FE's and he recommended them and said they were a great piston in the way they are designed.
79F-250bbf
Jun 9, 2015 11:40 PM
aclifton14
Mar 10, 2015 07:50 PM
351Cleveland C4
Jun 28, 2014 08:45 PM
rwrogers
Feb 22, 2014 10:46 AM
Yaga1973
Jan 5, 2013 05:48 PM
