Oh man another no start
Old Nov 6, 2022 | 07:59 PM
bismic's Avatar
bismic
You can, but the D-ring needs to be put on carefully.
Old Nov 6, 2022 | 08:08 PM
J ballan's Avatar
J ballan
Hmm good to know. I already have a new kit (stand pipes/dummy plugs) from Ford so hopefully I don’t have to worry about them anymore. Thanks
Old Nov 6, 2022 | 08:13 PM
J ballan's Avatar
J ballan
Also the FICM was only held on by the front bracket. Can somebody show me a picture of the rear bracket that I’m missing please and thanks. It’s a 2005
Old Nov 6, 2022 | 08:41 PM
bismic's Avatar
bismic
There were two different set-ups for the FICM bracket in 2005.
"All 2003 to early 2005 model year engines use stud type hardware to retain the thermostat housing, where the EBP sensor mounting bracket secures over top of that with nuts. Late 2005 and newer engines use only conventional bolts to secure the housing, due to the EBP sensor being relocated rearward, secured to the front FICM bracket."
Which do you have?
Old Nov 6, 2022 | 08:43 PM
bismic's Avatar
bismic
Nevermind. The rear FICM bracket that will fit the late 04-07 is:
4C3Z-12A659-CA (late 04 - 07)
https://www.tascaparts.com/oem-parts...t-4c3z12a659ca
Old Nov 6, 2022 | 08:48 PM
J ballan's Avatar
J ballan
Thanks a bunch. Mines the late 05 style
Old Nov 9, 2022 | 05:05 PM
J ballan's Avatar
J ballan
How sure are you that this is the right bracket? That looks like a front bracket and not the rear.
Old Nov 9, 2022 | 05:09 PM
bismic's Avatar
bismic
Sorry!
EDIT - If the above number is not correct then it is: 4C3Z-12A659-AA (it is one or the other)
After you get the correct one, please confirm in this thread, I have a few sources and they seem to conflict with each other.
FICMRepair calls the 4C3Z-12A659-AA the rear bracket (see link below) - so I believe this is the correct number!
https://www.fordpartsgiant.com/parts/ford-bracket_4c3z-12a659-aa.html
Enter the part number on their index page:
https://www.ficmrepair.com/index.cfm
Old Nov 9, 2022 | 06:23 PM
J ballan's Avatar
J ballan
Sorry!
No worries. Thank you for helping me out. Much appreciated
Old Nov 12, 2022 | 07:42 AM
IHateCommieCars's Avatar
IHateCommieCars
I'd go to the nearest Pick U Part place for that bracket. No one ever takes those, but they grab the FICM fast, so most of the removal work will even be done for you. Just check their inventory for a late model 6.0, they go get it.
When you told me that you got it to start after cranking awhile, I suspected a dummy plug/standpipe. That's often the leak point for slow starts/hot no-starts. That's almost surely your problem. Shaking my head that the PO would sell his truck as a non-runner (presumably for a low price), after doing all the work on it, without even checking the o-rings. Geezus, that 84IPR reading tells you it's a leak.
Old Nov 12, 2022 | 07:51 AM
J ballan's Avatar
J ballan
Ya you betcha. She starts and idles good now. I found a used bracket that should be here by Monday. Just waiting for that and a couple other little things and I can take it out on a proper test drive. Thanks
Old Nov 22, 2022 | 04:43 PM
J ballan's Avatar
J ballan
Ok finally got this thing all buttoned up and took it for about a 10 mile drive. It starts good but idles rough and seems like a misfire while cruising at 1/2 throttle or less. Seems to pull hard at WOT once the turbo spools. No engine light. Could this still be air trapped in the system or do I have other issues? Thanks
Old Nov 22, 2022 | 04:52 PM
  #28
bismic's Avatar
bismic
Could still be some entrapped air.
Old Nov 22, 2022 | 05:25 PM
  #29
J ballan's Avatar
J ballan
Ok thanks. I’ll take it for another good rip tomorrow
Ron73
Jun 23, 2022 10:36 AM
Michaelmonchamp77
Aug 14, 2021 04:25 PM
Kerly
Sep 17, 2016 01:18 AM
renchr56
Aug 25, 2015 07:46 AM
sixamskier
Aug 15, 2015 05:55 PM
