Lights flickering no crank
Old May 15, 2022 | 10:59 AM
Eoin Harland's Avatar
Eoin Harland
Hey I have a 2006 f250 and the other night I replaced a couple fuses and reset the air filter sensor and I started the truck afterwards and it ran perfectly then the next morning i went to go start it and it won’t crank and even trying to cycle it will cause the whole dash to flash and freak out.
I put both the batteries on chargers for a while and even hooked a jump box to it and all it is doing is draining the box.
Old May 15, 2022 | 01:36 PM
Don Naslund's Avatar
Don Naslund
which engine? Sorry, just noticed its a 6.0.
Might be a hydrolock. Try pulling the glow plugs and then crank it.
Old May 15, 2022 | 02:28 PM
Eoin Harland
hmm ok I’ll give that a try. It seems like it’s more of an electrical issue but it’s always worth checking every possibility.
Old May 15, 2022 | 02:42 PM
bismic's Avatar
bismic
I agree - seems like you need to make sure that the voltages are all ok first. We can only guess without any numbers.
Codes might help also.
Chainfire
Jan 15, 2022 07:59 AM
Angel Peredo
Aug 11, 2020 06:53 AM
packzitts
May 2, 2014 11:28 PM
baker1983
Mar 17, 2012 06:58 PM
