Re-install windshield… :(
Old Oct 17, 2022 | 08:05 PM
Makeryguy's Avatar
Makeryguy
Originally Posted by Obscure69
Well, I’ve ordered a new windshield for $500, it’ll be here in about a month. Tomorrow I am going to contact a local company to see what they might charge to install it. It sucks, but oh well, it’s just money…
I'd check w your installer to see what their price is for the glass- price for the glass itself through my guy was $125!
Old Oct 17, 2022 | 09:04 PM
1browski's Avatar
1browski
That really sucks on breaking the windshield. Im going to try putting mine in this coming weekend. Besides cracking the windshield, did that seam to go in easier for you while starting from the top?
Old Oct 17, 2022 | 11:34 PM
Obscure69's Avatar
Obscure69
yeah, I'm in Sweden, so I knew breaking the windshield was potentially a $1000 problem... there are no windshelds for a vintage Ford available unless I get it through a specialist shop like this one. Oh well, it's just money, right?!
Old Oct 18, 2022 | 12:00 PM
jfmaz's Avatar
jfmaz
Wow, sorry to hear about the break. Broke one once on my 68 VW bus, old windshield. Old glass, but still Ughh. One thing I saw watching the torture video, they didn't seem to use any slickum on the gasket. I always use wire pulling grease on the inside of the gasket to reduce the friction, and use the rope method. Sometimes the slicked up gasket can be a pain at the start cuz the glass / gasket is sliding all over the place, but when things get going and tight it is well worth it in my opinion. Gasket pulls over the flange easier. But then you have to clean it up after. .Just my 2cents, probably worth 1/8 cent after inflation.
Old Oct 19, 2022 | 05:52 PM
351Cleveland C4's Avatar
351Cleveland C4
Lube is your friend. I use WD-40 or silicone spray. Seems to work best with three people. Two people outside and one in the cab
I've done it on my truck two or three times now. It's never EASY, but with patience and LOTS OF LUBE, it goes together. Constant medium pressure from the outside and using a 1/8th inch Paracord seems to work best for me.
I can see where two people would be a struggle.
Old Oct 19, 2022 | 10:40 PM
Obscure69's Avatar
Obscure69
We used alot of dishsoap, WD-40 and silicone spray, and a 1/8" cord. I think the biggest problem was that the windshield being over 50 years old, probably had more damage than we realized, and couldn't take the force we were putting on it, whereas a brand new one would have been fine. all in all this is going to cost me about $700 for windshield and installation. Money I could have put to better use, but whatever, it has to be done, and my wife keeps saying "no use crying about it" :-)
Old Oct 20, 2022 | 10:54 AM
jzjames's Avatar
jzjames
Your wife is right.
One of my best lessons in life; “take your loss”.
Old Oct 21, 2022 | 08:40 AM
Obscure69's Avatar
Obscure69
Originally Posted by jzjames
Your wife is right.
Sounds like sound advice :-)
Old Oct 21, 2022 | 03:05 PM
RTT's Avatar
RTT
Red face
I do not beleive WD-40 is good for rubber
Old Oct 21, 2022 | 06:06 PM
351Cleveland C4
I don't think it's bad for it? I prefer to use it over dish soap or anything else with water in it. Rusting out the metal is a much bigger concern to me. As much as I drove the truck, a windshield only lasted 2-3 years. I never had any rubber problems in that amount of time.
Old Oct 21, 2022 | 06:41 PM
jzjames's Avatar
jzjames
When replacing windshield gaskets, try WINDEX for your lube. When things start to get a little dry just spray a little more in the gasket channel, windex also has drier in it and doesnt leave a residue, keeps things well lubricated when stringing in the gasket.
For the line, I use speaker wire, but peeled in half so you dont have the double strand. This worked best for me.
Old Oct 21, 2022 | 10:26 PM
RTT's Avatar
RTT
Post
WD-40 can swell rubber or buna rubber gaskets when the gasket is immersed in the fluid. If the fluid is sprayed on and wiped off, the gasket will not swell. This swelling will not ruin the gasket, however it will swell the rubber.
Silicone lubricant is the perfect lubricant for rubber surfaces, but it is also extremely versatile, so it can be used on most other materials, including metal, plastic, wood, and even painted materials.
I read other more technical details about different types of rubber & damage, etc...
Old Oct 21, 2022 | 11:06 PM
  #28
351Cleveland C4
An argument could be made that swelling the seal once installed could help it seal more completely.
Just coming at it from a different angle. I never had any leaks or trouble with them. Taking them out I always cut the face off with my pocket knife.
Old Oct 22, 2022 | 08:23 AM
  #29
Crop Duster's Avatar
Crop Duster
This is the best stuff to use. An old timer showed me this stuff 40 years ago. If you use silicone, you better not plan on painting your vehicle for a couple of years. WD40 would be better than silicone at least you can clean it off.
20g Genuine Castrol Red Rubber Grease Brake Caliper Fluid Rebuild Superb | eBay
BeholdenZippy
Feb 24, 2020 07:26 AM
niko20
Jan 18, 2019 03:55 PM
okiewelder
1961 - 1963 F100 Unibody
Oct 14, 2015 09:09 PM
clintonvillian
Feb 17, 2014 12:46 PM
84-250
General Automotive Discussion
Sep 25, 2008 04:19 PM
