Low beams quit troubleshooting help
Truck is a 2003 f250 7.3l truck with auto headlights.
I have the 3 power blocks under the hood. One is 4wd hi/lo and lo/hi relays. One is trailer tow stuff and with a/c and 3rd is DRL relays? But I have auto headlights?
Its a Canadian truck.
From my searching MFS could be culprit but wouldn't be the problem if I had power at rd/yel wire and rd/bl wire with lts on. This checked out ok
No power at headlight pigtail for low beam. Does have power for high beam
Low beam Fuses 46 & 47 have no power at all on either side of fuse. Fuse itself is ok.
Fuse 7 is ok
Help? Can the headlight switch be the issue? If so how can I test. How can I test continuity between MFS and low beam fuses? Not sure what pins on harness are headlight power on the back of the power distribution block. Can it be something else?
Do the DRL work?
It looks like power to #46/47 comes from Pin #30 of the DRL #2 relay. The MFS pin #9 (red/black) feeds pin 87a on DRL#2 12v when the headlights are on low beam. The DRL circuit feeds DRL #2 pin 87 constantly which should power the low beams while the MFS doesn't.
Do the DRL work?
My drl haven't worked in years actually. Everything else worked so I just didn't bother with it.
I'll have to Check the power at the relay. Red/black wire from the MFS must be the trigger wire for the relay.
Now dumb question of the day. Which of those 2 relay boxes is the trailer tow and which is drl? One closest to the fender or one closest to the engine?
The info you provided is exactly what I am looking for thank you!
The drl relay trigger wire comes from the drl module, it uses a series of relays and I didn't look into how they work together.
If your drl is inop and you don't care, (I dislike drl and disable it on all my vehicles) I believe you could remove the drl relay and jumper 30-87a, which should disable the drl and hard wire the MFS to the headlights. I'll double check the schematic...
I'm not sure which relay box is which.
You said you have power at the rd/blk coming out of the MFS, does it switch with the headlights switch on-off or the hi-low selector?
I wasn't overly worried about the 9v thing since that should be below the threshold to activate the relay 🤷♂️
Schematic shows the DRL and headlight relays are in 'Relay box 2' at the left rear of the engine compartment, for whatever thats worth.
I'll try to upload a schematic for you here, but I've had bad luck maintaining resolution uploading to FTE in the past.
I don't think it likes my .pdf, I'll try a screenshot as well.
Id prefer to fix this properly then run the jumper.
Pin 85 has constant 12v.
Pin 86 is a good ground.
30 to headlights
87 is drl with resistor. (resistor probably bad? Hence no drl?) I have power at fuse 14, but no power at pin 87
87a seems to function correctly with MFS.
Other than a bad relay, which doesn't seem to be the case, I've now tried 3 or 4 relays. Why would my low beams not function with a relay in place
30 to headlights
If so your gonna need to fix the open circuit or failed component between Fuse #14 and terminal 87 on DRL Relay #2. I agree from looking at the schematic that it's likely the resistor or connections to it.
I assume this is all with the key on?
Are you using the Auto function, or just using the headlight switch in the manual mode? Everything below is assuming the headlight switch is in the On' position, not 'Auto'...
If you have 12v at 85 the DRL relay #1 is closed and attempting to power the DRLs. Check for voltage at pin #1 of DRL Relay #1. For troubleshooting I think you can also remove Relay #1 and see if the headlights function normally sans DRLs. If DRL Relay #1 has failed (in the normally closed position) I think it would cause your low beam issues as well.
