First check for a blown fuse, then next it could be the hi/low switch that went bad, only working on the low side. Test for power at the headlamp socket. Of the 3 wires there one is ground and the other two go on and off depending on the switch high/low selection
thank you...I planned on that too. checking power at the pig tail harness. so there is a fuse that could go. Im guessing the hi low switch is in the passenger foot panel as when I put on High beams I hear like a relay click over there.
As much as I hate to say it, don't rule out the possibility that it's just the bulbs. I know it seems like a remote possibility but I've had this happen to me twice in my lifetime.
OK It does not seem to be the fuse as it "looked" good. but I will replace anyways as It can be the bulbs as they dont work when I plug in the plow harness...the go dark on the plow too. So Im thinking the pigtail is NOT getting power. Those fuses are small.
Is there something else to check or a problem with Body control module??
ordered new turn signal stalk switch today as the current one no longer stays clicked into high beam mode. Maybe its the switch. its acting funny so replacement worthwhile no matter what?!
