3G alternator question
Old Oct 10, 2022 | 02:55 PM
mk-F350's Avatar
mk-F350
4wd Low
I tried searching the site for information but it keeps telling me the keys words are wrong, too long etc.
I been reading on this conversion recently after charging troubles with factory style system.
And I’m wondering now , why does the alternator y’all use loop the stator wire back to the alternator?
My truck is a 85 f350 and from what I can find is my stator wire feeds my volt meter, correct? , if not can someone explain?
mice traced my stator wire ,light green with red strip, and it doesn’t go to the alternator, is it connected through the regulator?
Is the stator wire even 100 percent needed.
Old Oct 11, 2022 | 09:37 AM
solanum's Avatar
solanum
That's how Ford wired it on applications with a factory Third generation alternator.
I'm probably gonna get flamed for this and justifiably so, but on belt-drive trucks that already have the right mounting system I think you're better off installing a General Motors 10SI alternator. You can buy them brand new direct from ACDelco for $60, and if it ever craps out just about every auto parts store in the country has a replacement in stock. All connections (other than the output lug) are a standard 1/4" spade connector, so you don't need any proprietary harnesses to make it work.
Old Oct 11, 2022 | 09:43 AM
mk-F350's Avatar
mk-F350
4wd Low
I’ve also read and heard about the GM alternator also.
I also read in a mustang forum about connecting the stator wire to a ignition hot wire , which tells the alternator to start charging, but it seems like they were talking about some of the alternator not commonly used in the swap.
Thats what I’m wondering if it does by it being looped back into itself?
Old Oct 11, 2022 | 10:00 AM
solanum's Avatar
solanum
On 3G applications, the wire they're talking about is the "I" ("ignition") wire, which turns the alternator on.
The sole purpose of the "S" terminal is to turn off the warning light. The warning light is in series with the "I" terminal, which supplies field current to the alternator. When the ignition is turned on but the engine isn't running, the alternator consumes power, so there's a voltage across the warning lamp and it glows. Once the engine starts, the "s" terminal backfeeds voltage to the other side of the warning light, so it stops glowing. In theory you could do without it, but there are obvious downsides to this. As to why Ford designed it so there's a separate plug to worry about but it just goes back to the regulator plug, I couldn't tell ya. I guess the *%&#@^ guy who decided to use 573 different rear axles in every model was in working in the electrical engineering department that day.
Old Oct 11, 2022 | 10:09 AM
mk-F350's Avatar
mk-F350
4wd Low
That explains it a lot better bud, thank you. I just couldn’t wrap my head around it until now.
Old Jun 13, 2024 | 01:55 PM
corpsedub's Avatar
corpsedub
Wrong post
Old Jun 26, 2024 | 02:07 PM
okiewelder's Avatar
okiewelder
I have installed lots of the GM ones over the years. But, since I read how easy ford 3G is I have only been doing that conversion.
Rusty_S
Electrical Systems/Wiring
13
Oct 20, 2014 12:58 PM
Rusty_S
General Automotive Discussion
19
Jan 4, 2010 09:26 AM
1 F150dude
Apr 12, 2009 01:46 AM
drof46
May 5, 2006 09:09 PM
Ron Kelley
Aug 22, 2003 08:05 PM
