Alternator Alternative.
Old Apr 10, 2009 | 09:28 PM
1 F150dude's Avatar
1 F150dude
Ok I just thought that sounded catchy. My alternator went out on my '84 300 6 truck. I had to basically destroy the old alternator to get it off, because the bolt that goes throught it fused together with the aluminum in the casing. I have an high output alternator left over from an 89 Mustang build. I know i will have to change the pullies, but it has the regulater on the back. If I get the plug for this alternator, can I use it?
Old Apr 10, 2009 | 09:53 PM
Franklin2's Avatar
Franklin2
If you get it mounted you can use it. You will need to retrieve the green/red wire going to your old regulator and wire it to the new alternator. That's the wire from the keyswitch that triggers the alternator to come online. It will be either on the "s" terminal or the "i" terminal of the old regulator.
Old Apr 10, 2009 | 09:59 PM
1 F150dude's Avatar
1 F150dude
I compared the two, and the mounting tabs appear to be alike.
Old Apr 10, 2009 | 10:13 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Please post a pic of the back of the the alternator, or at least the overhead view of the regulator plug... need to know if this is a 3g high output or not.
Old Apr 10, 2009 | 10:37 PM
1 F150dude's Avatar
1 F150dude
Everytime i try to post pics it doesnt work. It it a stock alternator for an '89 Mustang GT w/ all electric options, a/c, ect.
Old Apr 11, 2009 | 11:10 AM
1980f150's Avatar
1980f150
Ford Fuel Injection 3G Install Tech
FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs
cant remember the differences between the 300 and the 302 and up, but lots of info at both those sites
Old Apr 11, 2009 | 08:21 PM
1 F150dude's Avatar
1 F150dude
Hey that was a cool link. I have the 2g, but i might swap it for a 3g. I can get the plug off an old parts truck at work.
Old Apr 12, 2009 | 12:56 AM
1980f150's Avatar
1980f150
i swapped mine for a 3g and it was very simple ,and wiring wasnt hard to do
Old Apr 12, 2009 | 01:46 AM
1 F150dude's Avatar
1 F150dude
I found a alternater upgrade kit for hooking up a 3G on a externally regulated '74-'85 Ford.
mustang81
Dec 29, 2014 08:31 AM
powerstroke1869
May 6, 2011 01:44 PM
lasthighboy
Electrical Systems/Wiring
Nov 30, 2008 05:07 PM
B Dobz
Sep 11, 2007 11:59 AM
medicpg
31
May 20, 2003 09:55 AM
