Engine swap. HELP!!!
Old Oct 10, 2022 | 01:05 AM
DEvans00's Avatar
DEvans00
1st Gear
I have a 2004 F150 XLT 4wd. It currently has the 5.4 Triton, 3 valve engine. It has nearly 300000 miles and has finally played out. I have been looking around and realized that to replace the motor with one of the same is quiet expensive. I'm wondering about the possibility of maybe taking the motor out and doing away with the computer and replacing it with a simple 302 or 351. Can someone tell me if it is possible to do using my current transmission and transfer case? And if so is it worth it? Thank you for any advise.
Old Oct 11, 2022 | 09:12 AM
Johnny Paycheck's Avatar
Johnny Paycheck
No, not doable. Transmission from the Windsors doesn’t have the same bellhousing bolt pattern.
You could drop a 4.6 in a lot cheaper, I bet, since it came as a factory option in your truck.
Old Oct 11, 2022 | 12:10 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Sure, it can be done. I am certain that making it work will cost FAR more than rebuilding your current engine, and it won't run nearly as well.
Old Oct 12, 2022 | 11:18 AM
ojai150's Avatar
ojai150
this is not a reasonable option unless you own a personal salvage yard , get another 5.4 and enjoy
Old Oct 13, 2022 | 08:57 AM
Trawlerphil's Avatar
Trawlerphil
I went with a 4.6 2 valve. The 3 and 4 valve engines are problematic.
Old Oct 14, 2022 | 04:30 AM
ojai150's Avatar
ojai150
give us more of an update, like you used the computer from the 4.6 etc ,..any other mods ?
Old Oct 14, 2022 | 07:52 AM
Trawlerphil
The original engine seized so I looked for a 4.6 2 valve and found one in a Charlotte junk yard. A local shop replaced the water pump and plugs before installing it, and it is running fine.
TurnzyF-350
Apr 10, 2020 09:21 AM
cworley250sd
1997 - 2003 F150
Jan 20, 2018 12:45 PM
dixie_mwbb
Offroad & 4x4
125
Jan 5, 2012 12:23 PM
live2hunt
Jul 15, 2003 01:47 PM
