Bad FICM?
Old Oct 8, 2022 | 12:38 PM
Bvretn1's Avatar
Bvretn1
Bad FICM?
Alright so yesterday I was on my way home and my truck died going down the highway. It didn't sputter or anything. The engine just quit like I had turned the key off.
So I got it towed home and the first thing I check was to see if it was fuel related. The fuel pump is running and their is fuel in the upper fuel filter bowl.
My next check was to test the FICM using a dvm. With the key on I get 55v and it drops down to 34v as the injectors start buzzing and jumps to 58v after they stop buzzing. Voltage while cranking goes from 58v to 38v.
I'm assuming my FICM is toast causing the engine to die and not start?
Video link below.
Old Oct 8, 2022 | 01:54 PM
xcrsp440's Avatar
xcrsp440
Do you have tools to look for codes? What system voltage do you have when running?
Old Oct 8, 2022 | 02:29 PM
Bvretn1's Avatar
Bvretn1
Just a simple SCT tuner. There are no codes that appear when I hook it up.
Also, the engine won't run so I can't see voltage beyond the key on and cranking.
Old Oct 8, 2022 | 03:29 PM
bismic's Avatar
bismic
If your FICM didn't cause your problems, then it will cause them in the future - send it in to be repaired AND upgraded. CircuitBoardMedics.com does good work and is relatively inexpensive.
The SCT tuner doesn't pull codes thoroughly, and it doesn't report EBP accurately, so you need a REAL scan tool. You need ForScan or ForScan Lite, with the appropriate OBDII adapter. Even so, assuming the voltages are accurate, you need the FICM repaired.
Old Oct 9, 2022 | 10:33 AM
Jokester00's Avatar
Jokester00
Fix what you know is broken first. Your FICM is toast, so take care of that issue now before you start chasing your tail with other things. It may end up that you also have other issues to sift through after the new FICM, but it's a process of elimination.
-jokester
Old Oct 9, 2022 | 01:27 PM
DSMMH's Avatar
DSMMH
Suggest you change the 70 amp FICM power relay. The contacts get pitted and burnt over time and cause that voltage drop you are seeing during cranking. Ask me how I know.
Ed
Old Oct 9, 2022 | 02:29 PM
TooManyToys.'s Avatar
TooManyToys.
It's that initial spike! I just had to get that in.......
Old Oct 9, 2022 | 06:15 PM
Bvretn1's Avatar
Bvretn1
Ed
Picked up a new relay from Oriellys and it didn't fix the issue. Was really hoping it was something as easy as a relay. I appreciate your input though!
Old Oct 10, 2022 | 09:14 AM
offroadfun's Avatar
offroadfun
4wd Low
The engine should start with those FICM voltages. I've seen them running with 18 volts, not well, but running. You have a different issue that is causing your no start. Have you checked fuel pressure? Have you checked HPOP pressure? That's where I would start. That FICM should be replaced soon, but like I said, it's not causing your no start issue.
Old Oct 10, 2022 | 09:29 AM
bismic's Avatar
bismic
The logic side of the FICM might be causing that no-start ..........................
Old Oct 22, 2022 | 05:40 PM
Bvretn1's Avatar
Bvretn1
So instead of just scraping this trunk, I decided I'll put some money in it and see if she will get me by for another year.
Anyhow, I decided to pull the ipr to see if the screen is torn or plugged. All looks good. With the ipr valve still out, I cranked the engine to see if oil comes out. Nothing came out. Not even a drop.
so with that should I assume it's the hpop?
Old Oct 22, 2022 | 06:28 PM
Jokester00's Avatar
Jokester00
Uhhh...what? I thought we were fixing a FICM first...
-jokester
Old Oct 22, 2022 | 06:32 PM
Bvretn1's Avatar
Bvretn1
-jokester
last week I pulled the ficm from a friend's running truck and put it in mine. Still wouldn't start.
Old Oct 22, 2022 | 06:53 PM
Jokester00's Avatar
Jokester00
I understand - you're using your buddy's FICM while yours is out to be repaired so you can still troubleshoot your no-start, right?
-jokester
Old Oct 22, 2022 | 06:58 PM
bismic's Avatar
bismic
Sure would be nice to have a good code reader take a look at the PCM information!
Checked for air in the fuel?
Last time I loaned a FICM to a guy using a DVOM on it, it came back fried ................ With a scan tool - why do people still mess with the screws under the plate??!! You can short things out of you slip up just a bit.
