compression
Old Nov 11, 2003 | 10:18 PM
justin23's Avatar
justin23
compression
i need the compression range or where i can go to get it for a 1989 diesel non turbo. i really would appreciate any help on this i cant find it anywhere
thanks
Old Nov 11, 2003 | 10:38 PM
Spectramac's Avatar
Spectramac
Usually in the high 300s- low 400s
Old Nov 12, 2003 | 09:27 PM
pnose's Avatar
pnose
Also the cylinders should be within 10% of each other.
Old Nov 12, 2003 | 10:20 PM
Thudpucker's Avatar
Thudpucker
An old diesel guy told me to crack the injector lines. Listen for the miss. If one doesn't miss, replace it. IE: "you don need no stinkin compression test"
I'd sure like to know what my individual cylinders compression is though.
Old Nov 13, 2003 | 05:33 PM
justin23's Avatar
justin23
thanks guys im running from 380 to about 410. they tell me it is good. my problem is that the truck runs great but after it gets hot i have a real hard time starting it. i have been told it was compression or a injector pump or ....... So i am trying to narrow down my work. if anyone has had an injecter pump goout could thety let me know what the signs are or just if you know
Old Nov 13, 2003 | 06:25 PM
pnose's Avatar
pnose
I did have an ip go out on me and the 1st sign i had was it would not start when up to temp.I used to have to wait 1-2 hours before it would re-start. What milage is on it? If no additives such as stanadyne fuel treatment was used(it adds lubricity to the pump) your lucky to get 100,000.
Good news on the compression though,at least you have some evidence to support putting on a new ip.
Old Nov 13, 2003 | 08:22 PM
justin23's Avatar
justin23
glad to hear someonelse tell me that i think it is my problem. so what is the best way to check my pump?
Old Nov 13, 2003 | 08:34 PM
Spectramac's Avatar
Spectramac
Does it have a hard time idling? One thing I've noticed on some bad pumps is they will stall after you snap the throttle and release.
Old Nov 13, 2003 | 08:56 PM
justin23's Avatar
justin23
no once it starts it runs like a top. ok 1st thing in the morning say it fires right off. i drive it about 20 miles then kill it. ok now if i try to start it right back say within a minute it will start right up. but if i wait say 30 minutes or so it will not crank off until it cools down. i need help bad its getting embarassing having to crank and crank. plus i cant think of anything else to do about it
Old Nov 14, 2003 | 05:55 AM
pnose's Avatar
pnose
If you want to be full sure i suggest removing the ip and take to a diesel shop for testing.Its not that hard to remove except for the 2 bottom bolts.I had to fab up a 9/16 wrench(cut off and weld on a handle).I also found it easier to remove the injector lines 1st.Remember though,dirt is your enemy,even in minute amounts,CLEAN everything before you start. Good luck.
ScottJM
24
Oct 22, 2018 05:45 PM
IsoGrifo
Oct 16, 2009 06:37 PM
Ranger1F150
31
Apr 9, 2007 01:31 PM
66 POJ
Dec 29, 2006 05:21 PM
deronyv8
Jan 6, 2003 06:25 PM
