Compression
Old Dec 7, 2002 | 11:25 AM
deronyv8's Avatar
deronyv8
Compression
i have a 1964 f-100 truck with the 292 y block motor. My question is what is the normal compression for it? whats psi should i have when i do a compression test?
thanxs for any info
Deron Siegel
Old Dec 9, 2002 | 07:44 AM
286merc's Avatar
286merc
Compression
CR is 8.8 and cranking pressure is 160.
Old Dec 18, 2002 | 11:17 AM
phjbbu's Avatar
phjbbu
Compression
Gotta be careful with the cranking numbers b/c they are a function of so many variables (ex: cranking speed is a biggie). If you're doing a lo tech comp. check, the rule of thumb is that you're ok if the cylinders read within +/- 10% of each other. I'm guessing that for what you're doing, that's a "good enough" check. A notch up would be the leakdown test and that's a more reliable and telling check. I've never seen numbers that high (160) in anything I've tested...more like 120 or so.
Paul
Old Dec 24, 2002 | 01:06 PM
himmelberg's Avatar
himmelberg
Post Compression
[updated:LAST EDITED ON 24-Dec-02 AT 02:09 PM (EST)]>I've never seen numbers that high (160) in anything I've
>Paul
my info has it that the 312 t-bird (270hp) specs show 160-165 psi at a CR of 9.7 to 1. would think that the lower cr would reflect 120-130psi readings in the tamer 292. ei. the 300 horse supercharged ran 8.3 to 1 CR and 120-130psi CP. himmelberg
Old Dec 24, 2002 | 04:44 PM
286merc's Avatar
286merc
Compression
Where are you guys getting your numbers from?
Im quoting Motors 24th Edition, cranking speed is not specified so they must be assuming a fully charged battery and a good battery/wiring.
PLUS they lump all Y blocks together per year.
Is there actually Ford data breaking it all down?
Old Dec 25, 2002 | 08:58 AM
himmelberg's Avatar
himmelberg
Post Compression
... got the data from the service bulletin examples in Eickman's "Ford Y-Block". my ford truck shop manual has the data for engines extant in 54 and 55 and not the 292. In 54, for example, the 239 engine cp ran 130 psi @ 7.2 to 1. himmelberg
Old Dec 30, 2002 | 04:08 PM
286merc's Avatar
286merc
Compression
That 239 info agrees with Motors.
Here is what they have for Y blocks;
1954 130
1955 130
1956-7 155
1958-62 160
These are for Ford, Edsel and Mercury cars only and they dont reference engine size or options.
With the large chamber later heads in particular I can see a reality gap here.
Thanks for the heads up.
Old Jan 6, 2003 | 06:25 PM
dover's Avatar
dover
Compression
deronyv8
Sep 25, 2011 07:14 PM
deronyv8
Jul 7, 2011 11:54 AM
deronyv8
1983 - 2012 Ranger & B-Series
Apr 2, 2008 10:46 PM
deronyv8
Mar 2, 2003 10:49 AM
deronyv8
Oct 7, 2002 12:29 PM
