changing ignotion switch
Old Nov 13, 2003 | 06:43 PM
Ford3504x4's Avatar
Ford3504x4
I have a 94 Ford F-350 4 wheel drive (not dually) and i need to take out the ignition switch, anyone know how?
Old Nov 14, 2003 | 06:10 AM
pnose's Avatar
pnose
In my 92 there is a small hole up under the switch in the column.Dissconnect the batts,turn key to run position ,stick a small screwdriver or better yet apin that will fit up in the hole,press in on the pin and pull out ignition switch.To re-install push in new switch ,make sure it goes in the same position it came out(in the run position). Re-connect batts and try it out.Good luck.
